SnapCoupler Blade stand? |
79fordblake
Orange Level Joined: 01 Jul 2010 Location: West Kentucky Points: 827 |
Posted: 08 Feb 2016 at 7:17pm |
den/southern illinoi
Orange Level Joined: 11 Sep 2009 Location: Sparta, Illinoi Points: 1931 |
That is like what came on the snap coupler blade. Basically a 1/4 inch by maybe 2 inch wide straight piece of metal that held the tongue at the right height. Same item was on other snap coupler equipment like the dirt scoup.
Den |
Own 5 720 garden tractors with associated equipment,1 620 garden tractor, 4 wheel 20 2-5015, 5020 and associated equipment and 2 electric forklifts. |
EPALLIS
Orange Level Joined: 12 Sep 2009 Location: Illinois Points: 1110 |
Den: Do you know what length of the stand was? My dirt scoop needs a stand if I ever unhook it. Probably have to have one made, unless someone on the forum has an extra one they would part with. Thanks in advance.
CTuckerNWIL
Just long enough to hold it so it will snap into the bell |
DSeries4
Mine has a stand too. It has a 90 degree bend at the bottom so the weight is resting on a larger area.
Orange Tractors
Silver Level Joined: 13 Sep 2009 Location: Butler, MO Points: 172 |
I used a block of wood (high tech, I know) under the tongue of my blade the last time I had it off. I adjusted the height until it matched the #53 plow, and when I backed into it, it worked.
Connecting the lift latches wasn't quite as easy as the ones on the plow though, those I can do from the seat. Robert |
79fordblake
Is it supposed to have a pin go through it to hold it when not it use? It drags the ground.
Ted J
Orange Level Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18704 |
Yep, it just drags along ........
On a nice FLAT spot, measure down from the center of the bell to the ground. That is how high the 'eye' needs to be. Just make the piece long enough for the eye to enter into the bell nicely. That looks to be a NICE blade! Good luck cleaning it up and getting everything loose and like new again. Edited by Ted J - 09 Feb 2016 at 7:43am |
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4409 |
I've found 2/3 of a 3 hole cement block works just right. Some of my equipment has the factory "stand" for those I have a tarp strap that I pull it back and hold it off the ground to keep from bending it while working.
FloydKS
Orange Level Joined: 12 Sep 2009 Location: S E Kansas Points: 7895 |
I have a couple of things that are not attached to the blade but are the right length so I can 'prop up' the blade at the right height...it simply falls when I hook on, then is ready to prop up the blade when I am finished OR when I what to hook up again...
CTuckerNWIL
Unless it is too long, it won't get bent while using the blade. You can go forward or backward and it just flips back and forth and doesn't hurt a thing |
