steering cylinder
19856020 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 19856020 Quote  Post ReplyReply Direct Link To This Post Topic: steering cylinder
    Posted: 06 Jan 2016 at 6:31pm
I have a deutz allis 1920 same as simplicity sunstar or agco allis 1920 steering cylinder is leaking internally ,steering is all over the place ,hard to control . anyway apparently they are non rebuildable and new one is $400 anyone know an alternative or is that my best option
716 917 918 1920 d17 6080
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2016 at 9:03pm
Take it to a good local hydraulic shop.  I am sure they could rebuild it.  Never heard of one that is non rebuildable.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2016 at 9:08pm
John Deere couldn't rebuild the header lift cylinders on the L3. Or they said they couldn't. Maybe they just didn't want that amazing Silver combine on their lot, for fear they'd be flooded with buyers!
talntedmrgreen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote talntedmrgreen Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 7:25am
These cylinders are commonly about $150, used, on ebay and elsewhere.  My hydro shop here gets about $200 for a cylinder rebuild that size, after claiming they need to make a new rod.  Careful as you ask around, and get a quote before they do the work.
Patterson B1*B1/B1Forklift*B10*BigTen/B1Loader*B110*B208*B206*616*Homelite T16H/T8/T7/RM7E*Landlord/Loader/Trencher*Broadmoor717*Serf525*2110*7790*Legacy XL*Twin 20*Squire9*Squire6*JCPenny 494
Post Options Post Options   Thanks (0) Thanks(0)   Quote 19856020 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 3:52pm
It sure looks like its non rebuildable there is nothing to take apart on rod end and outer housing is welded like that's how it was assembled. Also service manual and parts manual both state "must replace entire unit" If there is something im not seeing advice would be appreciated.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 6:20pm
some of those cylinders will come apart after removing the fittings from the cylinder
Post Options Post Options   Thanks (0) Thanks(0)   Quote talntedmrgreen Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2016 at 11:29am
A hydro shop would put it on the lathe and cut the welded end off, then reweld when done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote talntedmrgreen Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2016 at 11:30am
Some cylinders can be disassembled by removing one of the fittings, and popping a retaining ring off the end of the shaft.  It will then slide out.  The ring 'snaps' back on, when you slide the rod back in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2016 at 3:38pm
Are you sure it's in the cylinder? The control vale run by the steering wheel could be the problem.
