!@##%^ D17! |
Post Reply | Page 12> |
Author | ||
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11570 |
Posted: 21 Apr 2022 at 8:47am |
Yazzie, the way your luck is running, ya better watch when you go to the bathroom, your Johnson might fall off! LOL! Tractor won't start, no ice cream, that ain't right! Okay, I've read everybody's responses to this possible problem, but it sounds to me like its a spark problem, not a fuel issue. Your smoke is probably raw fuel. You can have spark down at the points, but it may not be reaching the plugs. We all go for the worst thing first, and usually it turns out to be somethin' stupid and ya look like Telly Savalas when you find the problem. Here in NJ, the weather has been nuts. One day 69 degrees, next day 37 degrees. You're in PA and you've had it worst with this goofy weather. I would simply pop the Distributor cap off, take a little Brakekleen and give the points a spritz and run a rag through them. NOT A FILE! You guys with your files are killin' me. You remove the cadmium plating off the points when you file them. The plating protects the points from corrosion. You make the condition worst when you file em' removing some of the cad plating. The next time you try to use the Tractor you have the same problem and you're in there filing points again to get it started and blaming the points. Yeah, there's a lot of Chinese crap out there fir' sure. I read last year about someone bad mouthing SMP Blue Streak points. They had to keep filing them. UGH! Anyway, from the weather changes, it wouldn't surprise me if the points are oxidized and the spark is going to the breaker plate and not through the Distributor cap to the plugs. You see all kinds of spark, but its probably grounding to the breaker plate. If you cleaned the points the way I suggested, and it still doesn't fire off, I would next try a condenser. If that Tractor ran beautiful when you parked it, it's gotta' be somethin' dumb and simple for it not to start. We always think the worst and start rippin' and tearin' into stuff and its almost always winds up to be somethin' stupid...... Check it out Tommy... Steve@B&B
Sponsored Links | ||
tbran
Orange Level Joined: 14 Sep 2009 Location: Paris Tn Points: 3248 |
New head work,,, fire out of the carb w/ether... you have an intake (s) stuck open - pull the tappet cover or check compression.. or the distributor has moved..
TomYaz
Orange Level Joined: 14 Sep 2009 Location: PA Points: 10319 |
yeah 7 yrs...but I was being ez on 'em LOL! ...I got the tractor going, was just being cute...right now I am stalled out trying to convert it to a NF.
Ray54
Orange Level Access Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4370 |
My how time flies,................. count again Tom. I have way to many projects that have stalled out too. This that and the other part of me that don't do what they use to do, probably never get done.
TomYaz
Crap! why didnt you tell me 5 years ago when I asked! STILL cant get it started!! ;)
only AC orange
Silver Level Access Joined: 06 Dec 2014 Location: Eastern Indiana Points: 412 |
Maybe distributor cap or dust cap is cracked? Found that to be problem on a D-14 we tried to revive couple weeks ago. Replaced dust cap and fired and ran like supposed to.
TomYaz
Well I guess you win the prize. SLI sent a guy out. It was the distributor cap. Center point worn. But I know I had *some* spark else there would have been no ether flame/smoke out the stack... Boy I really HATE these aggravating issues...What a time waste this was... at least it wont be tooo expensive.
alleyyooper
Orange Level Joined: 12 May 2014 Location: Michigan Points: 238 |
Puffing black smoke. Sounds like the engine is flooded to me. I would put every thing back together and find some one with a tractor or pick up truck, turn the gas off and pull the tractor for a bit then open the gas petcock back up and pull it some more should start.
Get that engine rolling a few RPM's more that the starter can. Al |
Brian G. NY
Orange Level Joined: 12 Sep 2009 Location: 12194 Points: 2198 |
The prior owner of my D-17 had had the head done and put on a real nice looking used intake manifold with all new gaskets. He could never get it to run on but 2 cylinders.
The day I bought it, I installed new plugs which did not help. When he told me he had put on a used manifold, I shot some carb cleaner around the intake ports while turning over the engine with the starter....fired right up! Took the manifold off and used a BIG file to level off all the ports on the manifold and put it back together. Been running great ever since.
stu(ON)
Orange Level Joined: 12 Sep 2009 Points: 377 |
Again, I will post this link for anyone who wishes to probe the internals of their TSX carb.
I have a Zenith, so won't comment more.
DougS
Orange Level Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
Remove the carb. Open the fuel shut-off under the fuel tank and let a bit of fuel run freely. If you are afraid to open the carb yourself take it to whomever rebuilt your tractor and have them look at the carb.
TomYaz
Yes, ran great when brought home - better than ever with new plugs, new head, rebuilt car. Unloaded it, parked it in shed and never ran it till now. Has to be crap in the carb.
AaronSEIA
Orange Level Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2534 |
I doubt it's ethanol in the gas. My WC sits for months on end with E10 in it and it'll fire third pull every time. Same with my B110 and B10. Sit for months with E10 in them and they fire right off.
Back to the basics. Make sure it's static timed right ( plugs on right wires), make sure the bowl has gas, you already checked the vacuum. All it needs is air, fuel, and fire at the right time. I assume it ran after the engine work? AaronSEIA |
SHAMELESS
Orange Level Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
an old combine we had had a needle in the carb, if it sat for over 3-4 days, we'd hafta take that needle out and work it up and down, it was spring loaded, but would stick. that allowed it to start and run fine after doing that.
Rick
Orange Level Joined: 11 Sep 2009 Location: Jonesburg,Mo. Points: 3641 |
I have a brother who is a "heavy handed tightener"...so-to-speak! He uses a pair of pliers or whatever he can get his hands on to tighten up the bowl! I always tell him..."that's why they call it a thumb screw"! LMAO! Hard headed redneck!
Rick
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50663 |
Sometimes the bail stretches or the pot metal that the sediment bowl base attaches to gets warped, from heavy handed tightening...
TomYaz
The ether was igniting. smoke-fire observed.
TomYaz
Got a new screen, bowl,gasket. Couldnt get it to seal. Didnt work fine for me.
JC-WI
Orange Level Access Joined: 11 Sep 2009 Location: wisconsin Points: 33667 |
Cheap ether isn't hardly worth crap... bought a case and you could spray thatrstuff like there was no tomorrow and then grabbed a differentcan and just a puff of spray did the job.
the screen was brobably a plastic screen, and between the diameter perimeter of screen may be bigger and the thickness of the plastic not allowing the screen to lay down in glass bowl lip, was what made it leak... the old screens were made of brass and the rims were thin thus allowing the glass bowl to seal against the gasket. Just some more of that stupid modern day "re-engineering that don't work right because it wasn't done right.
if your tank has a rust issue and crud in it, roll a fine screen and put in inlet of sediment bowl body. couple inches high with the top crimped over. in line car filter will plug fast if you have lots of fine particles floating. then you have to either reeplace of blow them out backwards...and usually happens out in the field.. and the taste isn't real desirable.
Maybe this will help in the carb dilemma.
Rick
Yeah, but when the sediment bowl screen doesn't catch all the crap, then you CAN install an inline fuel filter on a WD45. I've used them for years with no ill effects of any kind and they've always ran like a raped ape! I still have one on the WD45 that I have now...no problem there. Rick
You can run an inline filter, but why? You already have a filter that works fine...
Dswall
Silver Level Joined: 11 Jan 2014 Location: Lindsay ca Points: 260 |
I have ran inline filters on our wd's all my life. They run fine.
Auntwayne
Orange Level Joined: 23 Apr 2011 Location: Edwardsville Il Points: 1589 |
You can not run an inline filter on the WDs. There is a reason Allis Chalmers engineers designed the sediment fuel bowls.
john(MI)
If you tried ether and it didn't start then there is something wrong with the spark. I had a similar problem with my D14 and new points and condensor took care of it.
TomYaz
Probably not a bad idea. New Screen,bowl, gasket and it wouldn't seal at the time...junk
WD45
Orange Level Joined: 20 Sep 2009 Location: STAYNER,ONTARIO Points: 930 |
Tom leave the screen out and install an inline fuel filter between the tank and carb.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
NickT(Ky)
Orange Level Joined: 13 Sep 2009 Location: Elizabethtown, Points: 417 |
Our local fuel dealer has "conventional" gas that we keep in a bulk tank here on the farm. It is 87 octane but is not blended. No carb issues ever even on the small engines (chainsaws and mowers).
TomYaz
No I don't have kids running around here. Opened up the distributor and watched sparks galore. Pulled a plug with wire still attached and its sparked well..
But I think Its the needle. when I pulled off the fuel bowl under the tank I noticed my wire screen was not there...then I remembered. A year or so ago when I had this new bowl and it would not seal with the screen. Needing to get the harvest in, it sealed with no screen. Mental note..resolve this issue, need to get a screen back in there...mental note lost somewhere...So I think I got crap in the carb.
Dan73
Orange Level Joined: 04 Jun 2015 Location: United States Points: 6054 |
Well you could always talk some fine sand paper and lightly clean the points. I got tired of points and put in a pertronix kit so I am not really very good with cleaning and gapping points or knowing when they need to be gapped.
WestAllisWD45
Bronze Level Joined: 06 Nov 2010 Location: WI Points: 29 |
Is it remotely possible someone is playing a joke on you and changed the plug wires around? Just things I've seen with kids and a WD45
Condenser or points not getting you a good enough fire? You get spark for a couple hits, but not enough to keep going or start. Wish I remember half of what a AC mechanic tried to show me 40 years ago! |
