Loader not working properly. |
180shane
Bronze Level Joined: 04 Jan 2015 Location: Central Missouri Points: 32 |
Posted: 20 Apr 2015 at 9:02pm |
Thanks everyone for the help. Ended up being the male end of the hose . Replaced and works wonderful now.
slip knot
Silver Level Joined: 15 Aug 2014 Location: texas Points: 103 |
Had the same problem with my 500 loader. found one of the quick connects would let oil flow one direction but not the other. This was a while back and my hairs just aout grown back out. A real pita.
tbran
Orange Level Joined: 14 Sep 2009 Location: Paris Tn Points: 3248 |
you could do some trouble shooting and switch controls for tilt and raise, see if problem follows hoses.
tbran
yes
180shane
Are you guys talking about changing the female ends on the tractor or the male ends on the hoses?
kinghunter
Silver Level Joined: 30 Jan 2010 Location: Kansas/Missouri Points: 408 |
i had this same problem and it ended up being the ends i couldnt believe it because i couldnt tell defference between new and old but i changed them and it works great.
SHAMELESS
Orange Level Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
like Mack says...and maybe change the hyd ends...sounds like it's starving for fluid!
CTuckerNWIL
Do you have 2 remotes running the loader? One for lift and one for tilt?
180shane
Just checked, the fluids and they were good and the couplers were engaged fully. Still no luck.
Rick
Orange Level Joined: 11 Sep 2009 Location: Jonesburg,Mo. Points: 3641 |
Plenty hydraulic oil? Rick
MACK
Couppler problems, not pluged all the way in, bad point, not a matched set or worn out set. MACK
180shane
On my 180 when you pull the lever back to tilt the forks it doesn't move. It makes like a vibrating sound but won't move. The bush hog loader raises and lowers just fine but the tilt will not move. Thanks in advance.
