Hydrostatic Transmission Fluid |
V2Inc
Bronze Level Joined: 17 Aug 2015 Location: Ft Knox, KY Points: 32 |
Posted: 02 Nov 2015 at 6:58pm |
I need some advice from the field concerning fluid for the transmission on my 616.
The manual calls for Allis Fluid 821/401 and of course this isn't on the shelf anymore so I talked to a gentleman at Sandy Lake and he recommended Dextron Type A fluid. Isn't this GM transmission fluid? Did Allis chose this for their hydro transmissions? A little help please, I don't want to mess this up. |
Allis Chalmers 616 w/60" Blade, 48" Rotary Tiller & Plow - Cool Man Stuff
Brian Jasper co. Ia
Dexron A hasn't been made in many years now. If it was me, I'd use IH Hytran.
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78579 |
most of the aftermarket Hydraulic- Transmission fluids would meet the old 821 spec... Hytrans , Universal tractor fluid, etc are a few.
most auto transmission fluids contain a "cleaner" which might not react well with some hydraulic components / rubber / rings. Im not sure Dextron would be a good choice.
Rocket 88
Silver Level Joined: 12 Sep 2015 Location: PA Points: 57 |
V2
Like Brian said I have used JD Hygard in my 912. A buddy of mine has used his Kubota UTV trans oil in his 900 series and claims it works better. I still have a old car that has the clear dextron oil in a hydramatic transmission it would be cool if they still sold it but now it has to be red dyed. |
farmtoybuilder
Orange Level Joined: 11 Sep 2009 Location: Dresden,Ohio Points: 1453 |
Use any brand of the current hydraulic -transmission oil for modern tractors.
ctbowles58
Orange Level Joined: 17 Jun 2011 Location: Clarksville, MO Points: 2249 |
my 712H calls for ATF.
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3344 |
it calls for dex or dexron iii my 616 has it in but we done a 720 a few years ago that had a loader on it so we changed the trans to a power trans. hyd. oil so all his oil is the same . we are currantly getting mobil brand in bulk and our dextron iii in bulk. it works just fine reason we did not do our 616 to hyd fluid when we got it running was know one new if the trans was any good so we changed the oil and filter and put dex iii back in by the way the 720 parts tractor had atf in also i will change mine over to hyd when it gets serviced next if you are using the equipment in differant tractors you will want your fluid all the same
Jordan(OH)
Orange Level Joined: 11 Sep 2009 Location: Celina, OH Points: 1545 |
821 is available from agco.
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41272 |
Many of the other brands of hydrostatic transmissions call for 10/30 or 20/50 oil , as far as universal trans-hyd oils - read the MIL spec on label if it meets requirements of .
ATF has changed over the years also - in my cycles I use ATF type F in primary chain case as the clutch plates get oil mist from chain and the Type F seems to be less cause of clutch slippage with multi-disc clutch.
BrianC
Orange Level Joined: 16 Jun 2011 Location: New York Points: 1614 |
Allis-Chalmers Power Fluid 821 is now AGCO Permatran 821XL.
