exhaust temperature |
200 allis
Silver Level Joined: 11 Mar 2014 Location: new jersey Points: 201 |
Posted: 26 Nov 2014 at 12:25pm |
I have 200 with 301 have 390 head on pump is hx 35 turbo looking for ideas to lower exhaust temperature.
Tim-tn
Silver Level Joined: 15 Sep 2009 Location: West Point ,TN Points: 205 |
If you use it only for pulling and rules allow it, water injection will help.
Peterson
Orange Level Joined: 05 Mar 2011 Location: Westboro, Wi Points: 862 |
How hot is it getting?
200 allis
Around 1800 close to 1900 I back off it.
200 allis
I am running 12cm exhaust housing was wondering if a 14cm would help
200 allis
Water is what I was leaning towards easier to hide then air intercooler
Peterson
Wow that's pretty hot!!!! Wastegate hooked up? Boost pressure?
Edited by peterson - 26 Nov 2014 at 8:06pm |
200 allis
Waste gate tied shut
Orange Level Access Joined: 12 Sep 2009 Points: 19644 |
Spray windshield washer fluid into the turbo as far away from turbo as you can get. Rig up a nozzle to spray 12 ounces in 30 seconds to start. Too much will bend connecting rods.....start with 12 oz in 30 secs. Put a switch on the throttle so it runs on the juice 1 inch before full throttle. Always get out of the throttle just before you stall it to prevent water logging the engine. We used to stick a windshield washer tank inside the air cleaner body....out of sight.
Peterson
Whats your boost pressure?
200 allis
Would one of the water injection kits that read off boost work.
200 allis
Actually I broke my boost gauge before last pulls so I don't know what it was running. Ed set up pump and injectors and it runs strong.
Peterson
Well more than likely you are out of the compressor MAP of the turbo with getting that hot. Also you've more than likely have melted the divider and the exhaust wheel of the turbo getting that hot. I would recommend atleast a hx40 with the 10 blade turbine and the 60mm inducer.
Peterson
Or go with a Borg Warner turbo in a comparable size. Pushing anything over 40 psi is just blowing hot are into the motor.
200 allis
I'm only turn 3000 rpms it would have enough to spin a hx40. Nothing melted still running fine. How are guys keeping them cool with a 450 head.
one54dodgetruck
Orange Level Joined: 25 Jul 2011 Location: rochester, wa Points: 396 |
would advancing the timing help? how about quad turbos
2 WDs
B B112 D14 D15 185 7040 pd |
Advancing timing 2 degrees at a time will help, BUT there is a point of tooo far advanced.
O.P.S. Heads
Orange Level Access Joined: 02 Jan 2013 Location: Iowa Points: 574 |
Keep it simple. Add water injection if allowed.
Advanced timing may cool it off a little. I would not go past 38 degrees and that would be if you have hardened connecting rods. Before you go changing exhaust housings it would be good to have peak pressures on both he intake and exhaust sides. The HX40 may be too big with a .390 pump at 3000 RPM. In theory the larger exhaust wheel on the 40 would reduce exhaust temps. There are three different exhaust wheels for a 40. Again in theory a .450 pump may cool it off too. More fuel = cooler exhaust temps IF you use the same turbo. You may have to use a larger exhaust housing to keep the turbo from over speed / over boost as more fuel will drive the turbo harder. Shoot for 1400 - 1500 peak degrees max. Edited by O.P.S. Heads - 29 Nov 2014 at 8:35am |
AC200Puller
Orange Level Joined: 04 Dec 2011 Location: Wisconsin Points: 774 |
Water injection works for me. I have a pressure switch in the manifold that will turn on at a preset boost and shut off when below that.
Slade (TN)
Orange Level Joined: 12 Sep 2009 Location: TN Points: 676 |
I'm surprised you're not having trouble with the head at those temps
Slade
Peterson
Im surprised a piston or two are not melted...
O.P.S. Heads
I have never seen a 301 puller (with original AC pistons - not aftermarket) melt the tops of pistons due solely because of high EGT's. They will crack heads and drop exhaust seats (if used)like there is no tomorrow as Slade said.
200 allis
I was wondering if some of it could be a false reading maybe some fuel ignite in exhaust manifold.
So, when you are at a night time pull, are you seeing fire out the exhaust pipe?????
200 allis
Haven't pulled at night but have played around the farm with it and flame comes out of pipe.
