How to remove the Throttle Quadrant on a WD |
Alex09(WI)
Orange Level Joined: 15 Mar 2012 Location: CECIL WI Points: 1699 |
Thanks(1)
Posted: 12 Jun 2014 at 7:34pm |
This how-to article explains how to remove the aluminum throttle/hyd quadrant on a WD without removing the levers.
Start by removing the pin in the steering U-joint. This pin is pressed in and some of them can be stubborn to remove. 60% of the pins I have tried to remove, needed partial drilling to get punched out. 40% I punched out without any drilling. If there is a bolt instead of a pin, its your lucky day. Normally there is an engine in the tractor and the pin will be difficult to punch/drill out, but it can be done. It will be easier when the magneto or distributor is removed. It will be even easier yet if the magneto drive/governor section is removed.
Then slide the steering wheel and shaft out of the support post and quadrant.
Remove the bolts that hold the quadrant to the steering support. Next loosen the quadrant from the steering support. Then remove the friction blocks from the levers. Some may need a bit of persuasion to slide off. Turn the levers so they are both pointing down. Next, pivot the quadrant so the top moves back and and slide it down off the levers. When installing a different quadrant, follow the procedure in reverse. |
www.awtractor.com
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22816 |
Never would have thought it would come off that way.
fixer1958
Nice thought process.
Your hand got dirty though. |
den/southern illinoi
Orange Level Joined: 11 Sep 2009 Location: Sparta, Illinoi Points: 1938 |
Definitely works, been doing it that way for several years. Den
Own 5 720 garden tractors with associated equipment,1 620 garden tractor, 4 wheel 20 2-5015, 5020 and associated equipment and 2 electric forklifts. |
GT in Indiana
Orange Level Joined: 14 Sep 2009 Location: Indiana Points: 213 |
Pretty slick! I was almost there but didn't think of turning the control arms down
Great post... |
1955 WD45 we like to call Ruby
macvette
Orange Level Joined: 13 Jun 2011 Location: nekoosa, wi Points: 1656 |
Appreciate your posts, Alex. Thanks.
Installed the quadrant quite a while ago that I bought from you, and yes, removing the pin from the steering u joint was miserable. Used a bolt with ground down head and nut when reinstalling,tho! (my WD does no work for its living, tho.)
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8070 |
That quadrant still has the lines/grooves!
Jacob (WI,ND)
Orange Level Joined: 11 Sep 2009 Location: Kenmare, ND Points: 1245 |
Good to know! and EXCELLENT article!! This is exactly what we need more of, thank you for putting it together!
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45 |
Alex09(WI)
Moderator: Would this post be accepted in the "Knowledge Base" Section?
www.awtractor.com
CTuckerNWIL
Brian Jasper co. Ia
Thanks for posting this. I have a WD that needs one badly.
Ted in NE-OH
Orange Level Joined: 12 Nov 2009 Location: Austinburg OH Points: 1703 |
Thanks, I need to do that.
BradH
Orange Level Joined: 28 Feb 2016 Location: Corydon Ia. Points: 264 |
Happened to be looking through and notice this topic. Need to do this on mine pretty bad but wasn't looking forward to the job. Was thinking about asking on here soon. Perfec timing, Thanks.
Warning! Blind man with a tractor! Head for the hills!
LaJaMe
Bronze Level Joined: 14 Sep 2014 Location: wisconsin Points: 170 |
Thanks for the post. I have a wd that needs one.
Moderator: Could use a post on adjusting the hand clutch on a wd and wd45. Thanks
