Allis Chalmers forklift Engine options
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers forklift Engine options
    Posted: 22 Jan 2010 at 8:52pm
Can anyone tell me what engine were used in the Allis Forklifts. Did they use a Buda 262 propane? or was it a 230.
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 9:04pm
Depends on which model we're talking about. I worked in a warehouse that had an old Allis forklift. It had a Continental engine in it. I guess it depends on what model industrial tractor for a 230 or 262.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 9:29pm
Jim, what are you up to now?  A-C used 153, 230, and 262 engines in forklifts. I have a lot of forklift info so if you have the forklift model, I'll check it out for you. Remember I'm away next week. Are you comming to the Club meeting Saturaday?
Bruce Mn. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bruce Mn. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 9:46pm
Calvin, thats good to know, I've got a fork lift but don't know much about it . been told it's probably a buda engine in it. looks alot like a WD engine. I think it's a 400 series maybe?
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 9:59pm
  is that a cyl.  neighbor has one like that    thinking it is a continental  is it a flat head or overhead valves cannot see engine  1-574-342-4545 for more info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bruce Mn. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 10:04pm
norm i'ts an overhead valve 4 cycl.
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 10:47pm
Calvin, I am going to look at a six cylinder engine that came out Allis Forklift. Its a buda not sure if its a 230 or 262 was a propane engine. It maybe be good to have for parts...etc
Not sure if I can make the meeting. Have a great trip if we don't talk before you leave.
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2010 at 6:45am
My A-C forklift has the Buda diesel in it,looks same as yours,though I'm missing those louvered side covers.I had 'fun' replacing the fanbelt last month.The small weight under the rad grille weighs in at 310# AND you have to remove the hyd. pump as well.
Tough beast, lifts 5000# without complaining.
The nameplate should have stamped info,mine was very hard to read though.
Jay
Ken(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2010 at 8:47am
I have an Allis forklift with an Allis 160 engine in it, Canadian built, 4000 lb. with pneumatic tires, and another one with a 140 Continental, 2000 lb. with solid tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 7:08pm
  bruce give me a call  ran into this couple weeks ago  may be a  BUDA  153  WANT TO ASK MORE QUESTIONS   1-574-342-4545  is there 1 bolt  holding the water pump on????
CWI_Tugger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CWI_Tugger Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2024 at 1:26pm
I have a C40 forklift, inline 4cyc gas motor with a G420.   Which was made by Mitsubishi as their 4G52.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2024 at 1:31pm
4 cylinder, 2.0 Liter Mitsu engine..... i didnt know that !
Post Options Post Options   Thanks (0) Thanks(0)   Quote CWI_Tugger Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2024 at 2:10pm
uploads/24414/G420_2024-01-12_14-09-27.jpg
Not sure I uploaded the picture correctly but hopefully it will show up.  LOL
