Changing a Grader Tyre |
Ian Beale
Orange Level Joined: 03 Oct 2011 Location: New South Wales Points: 937 |
Posted: 09 Aug 2012 at 5:14am |
The motive power is a FA 10. The quick drop valves make it work as a hammer. The frame is easier to move around than the wheel, and, when turned up, helps get the wheel centre out once the beads are loose.
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41256 |
I took a old rim and cut a slot across it so the rim expanded slightly , then use that to let tire fall onto when de-mounting tire.
Backhoe bucket worked well for most tires - until I ended up putting tooth through sidewall on one of my 13.80 x20 float tires on dump truck. Those old tires seems to want to stick to bead area .
Ian Beale
Coke,
When they look like this
they're a problem. We had to get the matching one off to get the grader home. Had to chainsaw the wheel centre out and oxy the beads off. I'm pretty happy that this rig got this one loose. Saved all the tubes as well.
Scotchenomics on used tyres here. If you don't save the tube you need to buy a new , one which needs a flap or it is likely to split on the seam somewhere. Add about $A200 or so for this, plus cost of a second hand tyre very quickly comes close to the about $A600 for a new Chinese tyre, tube and flap.
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29809 |
Looks like you got all the goody out of that one! You could almost see the air inside while inflated and tell when it was going bad!!
Ian Beale
DMillar,
We inherited it like that. The good was got a ling time before! Did its bit foe CO2 when we burnt it though.
Coke-in-MN
When I got my Adams 411 grader I got 4 extra tires with it , only problem was those tires were mounted on dayton open center type rims where the Adams had a solid center rim that bolts to hub. I also saved the tubes by having new valve stems vulcanised onto old tubes . One front tire I have a liner in it as sidewall has a few weak spots .
HD6 Merv
Silver Level Access Joined: 03 Aug 2010 Location: New Zealand Points: 476 |
Gidday Ian; had a mate with simila problems with a scoop tyre.
They used a rockbreaker to impact it off Just another idea ! cheers merv
tits tyres and tracks
they all cost you money |
Ian Beale
Merv,
My father had a quote which went
"Do the best you can with the material in hand"
Or as friend back from a stint in the NT in years past reckoned
"Necessity is the mother of invention and the father of halfcastes"
patrickmull
Orange Level Joined: 11 Jan 2011 Location: Casey IL Points: 893 |
that is neet
