Engine will no turnover |
Page 123> |
Author | ||
Chugach ![]() Bronze Level ![]() ![]() Joined: 30 Nov 2023 Location: Alaska Points: 32 |
![]() ![]() ![]() ![]() ![]() Posted: 17 May 2024 at 6:21pm |
Hello,
My D15 Series II was running just fine. Went to restart and a clanking noise came from front of tractor so I shut her down. Now it will not start. Dropped the oil pan and crank and all look good. Can’t get the crank shaft to move. Any suggestions? Thanks, Chugach |
Sponsored Links | ||
Les Kerf ![]() Orange Level ![]() Joined: 08 May 2020 Location: Idaho Points: 686 |
Since you already have the oil pan off, the next step is to determine if the trouble is in the piston/cylinder area or elsewhere. Pull the rod caps off one at a time and see if you can move the piston upward. If they all move, then it is probably in the cam gear/governor gear area. That is the most likely from your description of the noise, but you do have the pan off so...
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 78579 |
governor failed... pull it out.
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3344 |
did you pull the starter and make sure it isnt broke
ryan(IN) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Bluffton,IN Points: 748 |
This. Occasionally the starter on my D14 loosens the pinch bolt and it will turn ever so slightly. Go the start it. Acts like it’s locked up tight. Turn the starter. Fires right up. |
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62 |
Unless the starter is jammed into the flywheel I don't think it would create the above symptom. Steve's suggestion of governor failure is most likely the culprit
ACinSC ![]() Orange Level ![]() Joined: 16 Dec 2015 Location: South Carolina Points: 2620 |
When I bought my D 15 the seller said the engine was locked up
He had the oil pan off. Favorite son and I were able to bar the engine over at the flywheel Starter had it locked up. Just saying |
Starter and Governor a both good ideas... Do the easy one first ?
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21720 |
re: tried to restart-clunk-jammed my monies on.... Starter.... disconnect battery, remove 1 bolt, remove starter put long screwdriver in bellhousing, test turn the ringgear..... |
Three very experienced posters have stated that this can indeed happen on this engine Edit: Four
Edited by Les Kerf - 18 May 2024 at 10:23am |
JC-WI ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: wisconsin Points: 33703 |
Put it in high gear and rock it backwards. might unstick a stuck starter... If that doesn't do it take the starter out and see if the engine will turn one way or another. Maybe dropped a valve?
Thanks Les
Thanks everyone! I have taken the starter out and bench tested and that is working fine. I am heading towards the timing gear cover. A lot of old oil on front of engine. I will try the other suggestions. I appreciate the help because I am not much of a mechanic.
Chugach |
remove the starter and it is FINE...I assume you tested, but try to rotate the engine ? STUCK starter can still be a good starter...
Thanks Steve. I will pull the plugs and try to turn the crankshaft
Removed the rod caps and all pistons move. Tried to move the flywheel through starter hole and failed. Back to removing the timing gear cover, do I really need to do a front split and move the front assembly away from the tractor? Thanks again, Chugach.
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 4445 |
Just curious (and probably stating the obvious), but does it still not turn over with the (foot) clutch depressed?
Yes
Thanks for the link Steve!
All is well with the distributor side, I had high hopes
DANG... i was hoping you would see a broken weight or pin !
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 19716 |
Governor goes out the front, not the rear.
yes... guess im getting ahead of myself.. need to read closer..
Bearing seems a little wonky
55allis ![]() Orange Level ![]() ![]() Joined: 30 Jun 2020 Location: Griswold Iowa Points: 583 |
Is this just my eyes or is something missing?
In the red circle? ![]() |
![]() Here is the cover |
Nothing there that has "locked" up the engine. Is there a loader on this tractor with a front hydraulic pump??? Do the fan blades turn when you push/pull on them ??
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8193 |
Did something find its way into a gear. Cam,crank,governor
Page 123> |
