7020 pto problem
youngorange2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Topic: 7020 pto problem
    Posted: 12 May 2022 at 5:18pm
I am in the process of replacing the seals on my 7020 pto. I drained the fluid removed the safety wire and pin loosened the big nut and went to pull the 1000 rpm shaft out and got it about 4 inches out and is now stuck and won't go in or out. There's a bearing on the inside of the shaft that's stuck up against the big nut. I have tried working the shaft in all directions and tried gently prying inbetween the bearing and big nut and it will not budge. I'm stumped
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2022 at 5:51pm
You need a BIG slide hammer attached to the outside end of the 1000 RPM shaft and slide hammer that bearing off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2022 at 9:32pm
I got the PTO seals done. I ended up using 3 7 inch 7/16 bolts going through the 1000 spline shaft and the PTO itself as a slide hammer. The stuck bearing came out with half a dozen light taps of the makeshift slide hammer. Thanks for the help
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2022 at 9:48pm
That's the way I've always done it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2022 at 3:39pm
yep...me too, mine needs it again
