Antique Ten Horsepower electric motor.... |
Author | ||
turbokinetic ![]() Bronze Level ![]() Joined: 30 Jan 2019 Location: Alabama USA Points: 19 |
![]() ![]() ![]() ![]() ![]() Posted: 30 Jan 2019 at 8:23pm |
Hello folks. This is my first time posting here, and hope you find this interesting and may be able to shed some light on my antique motor.
I located this Allis-Chalmers electric motor being used an a yard decoration in central Alabama. The owner was moving and wanted to get rid of the motor. He explained that the motor had been part of his grandfather's gristmill many years back and it had not been in operation for about 30 years. My question is, does anyone know of a way to estimate the manufacturing date of this motor? It appears to be 20's to 30's vintage, based on the styling of it, and the ring-oiled journal bearings. But I am not really an expert and would like to know if the motor's nameplate can shed some light on the manufacturing date. Edited by turbokinetic - 30 Jan 2019 at 8:27pm |
Sponsored Links | ||
Here is a video where I test the motor out... |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 78566 |
I cant help on the year, but I thing your close with your 20-30s guess. I worked at a plant with a bunch of 1940- 1950 motors and they were not that OPEN on the side covers.. More covered up / finger protectors.
Thanks Steve. I also acquired another early A-C motor, which is more enclosed. It's got Timken tapered roller bearings instead of the journal bearings on this one. Does this look like what you saw at the plant? https://youtu.be/0Rz51yqEnrw
https://www.youtube.com/watch?v=0Rz51yqEnrwyea, like that or a little newer. Most of the smaller motors we had used ball bearings on the ends and were greased once a month...... The larger 100- 600 HP motors had sleeve bearings and an oil cup on each end. Glass bulb was monitored to keep them full. Most of the end bells were somewhat "open" compared to motors built today, but not near as open as yours is........... ours were 1940 vintage.......... many built just AFTER WW2.
Must have been a very neat facility to work at; although back in the day I know things may have been somewhat harder on a day to day basis. I love the glass oiler cups, as well. That design sounds like my 1925 B.F. Sturtevant 42" exhaust fan motor. It's a Western Electric with glass oiler cups. |
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8190 |
Welcome to the forum. Are you a allis collector
WOW.... never seen BRACES tapped into the motor housing itself ! That's one of a kind !
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21719 |
I'd have thought 'newer' as it's 60HZ, most everywhere was 25 cycle until mid 50s ? Sure is a NICE piece though !!!
tadams(OH) ![]() Orange Level Access ![]() ![]() Joined: 17 Sep 2009 Location: Jeromesville, O Points: 9773 |
Must turn the pipes to fill the oilers cause you would make a awful mess other wise
Jay, we have several power plants that were built in the 1925-30 -40 era and they were 60 hz in the Midwest USA...... I cant speak for everyone... Now the early generators on the EAST coast in 1880- 1890 era were lower Hz.
apparently WESTINGHOUSE set the standard at 60 Hz for the USA..
Westinghouse Electric decided to standardize on a lower frequency to permit operation of both electric lighting and induction motors on the same generating system. Although 50 Hz was suitable for both, in 1890 Westinghouse considered that existing arc-lighting equipment operated slightly better on 60 Hz, and so that frequency was chosen.[5] Frequencies much below 50 Hz gave noticeable flicker of arc or incandescent lighting. The operation of Tesla's induction motor required a lower frequency than the 133 Hz common for lighting systems in 1890. In 1893 General Electric Corporation, which was affiliated with AEG in Germany, built a generating project at Mill Creek, California using 50 Hz, but changed to 60 Hz a year later to maintain market share with the Westinghouse standard.
YEP.......... kind of looks like the gas filter on an ALLIS B ???
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29912 |
This would be a Proper Bubbler type oiler
https://www.tricocorp.com/product/opto-matic-oiler-glass/# Bagnall dam had motors similar to this one for summer ventilation drives. They were Westinghouse but very similar size shape and 60hz, built in the 1920's/30s Edited by DMiller - 01 Feb 2019 at 3:21pm |
Thanks so much for the replies! I wasn't getting notices for some reason.
Those oilers on the antique fan motor aren't that bad, actually. The oiler assembly, with the metal base, will rotate and "cam out" of the pipe ell fitting. It works like an 1156 light bulb, where you push down and turn it to release it. Once it's out, you can turn it upright, remove the metal cover, and refill it.
Very interesting. If I remember, the oiler on the Sturtevant motor is Trico branded as well. Yeah they had 60 Hz power back in this day. They also had other frequencies as well. Just nothing was standardized! I made some more testing on the Allis-Chalmers motor today. My fear for this motor was that the winding was damaged. That could have been caused by the rotor rubbing the stator, and causing a localized hot spot. It could also have been caused by moisture and dirt in the winding. When I got the motor, it had a very poor insulation resistance value; just several KΩ of resistance. This was because the winding was caked with dirt, grease, feed dust, moss, mold, and other debris. That was causing a resistive short to ground, which could have burned the winding out, had the motor frame been grounded when it was running. I tried solvent to clean the winding, but it was not cutting the soil, since it was mostly non-petroleum materials. I had to resort to mild dishwashing soap, and the pressure washer. That blasted away the crud. It improved the insulation to several hundred KΩ of resistance, but that's still dangerous. My go-to method for drying a winding is to put a lot of amps through it with a DC supply, such as battery charger. In this case, the motor is so massive that even my biggest charger pushing 35 amps through it, only made it "warm" and not hot. It took a portable heater, a blanked over the stator, AND the charger to get it piping hot and drive the moisture off. The video of testing the insulation is here: https://youtu.be/QQBPMf7g_JU [TUBE]QQBPMf7g_JU[/TUBE]
DonBC ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Courtenay, BC, Points: 904 |
A few decades ago I worked for a school system and occasionally a school's basement might flood because of a burst pipe or major rain storm. Our electrical maintenance dep't had and old electric range in their shop where they would place the drowned electric motors in the oven and 'bake' them dry.
At the Power station we would pull and send our larger electric motors out for rewinds due to insulation and varnish/enamel coatings break down from heat as they ran almost constantly. Most of ours were later model 'Squirrel Cage' aluminum bar induction motors. Zeller electric in IL was our source for a long time, they have now moved to other suppliers.
That's a great idea. I could use an old oven for that, and for baking paint / powder coatings. But yeah, moisture needs to be combined with electricity (at significant voltage) to do damage to motor windings. If the motor isn't in operation, at the time it gets wet, you can just dry it out and it will be fine. The bearings, however, may need more in-depth service if they got filled with water as well.
Understood. There's a lot of debate about the expected life span on most industrial motors. The average reported life from across the industry seem to be in the 10 to 20 year range before a major failure. It seems that it's so dependent on the application that one has a hard time predicting motor life in any new application; however once a trend is established it's usually repeatable unless something changes in the application. Were the powerstation motor rewinds done based on measured parameters with the motor, before a failure - or were they done when the motor finally did suffer a major failure? Sincerely, David
Usually based on heat display(thermal imaging) and amperage changes over time in use, the engineers could track that parameter. Amps go up voltage down and heat ensued in maintaining work(watts). Most as I noted were continuous driven motors, our Condensate pumps from the Steam condenser were Allis Chalmers built in the late 70's, they had to be rewound every other year as they ran so hard and so hot while having water cooled bearing oil coolers. We had other AC units but they had the added Siemens nametags.
Sounds like they had the maintenance / rewind schedule pretty well figured out. I bet those were high speed motors as well, probably driving multistage pumps for the condensed water. I bet there was a lot of bearing heat involved to need that sort of oil cooler. Some of our generators run at 1800 RPM and use journal bearings which have water cooled oil coolers. I bet the condensate pump motors were running about twice as fast.
Hi Folks. A friend over on the Antique Fan Collectors' Association shared these book pages with me. This book is from 1914 so it seems this motor may be a few years older than we first assumed.
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 5652 |
Although higher frequency operation allows smaller transformers and motors at the same power level, there's a pile of tradeoffs that come on as frequency increases. The 60hz standard was not so much chosen for electrical properties, as it was for OTHER purpose: Timekeeping standards. George Westinghouse was a railroad man... by using a 60hz base frequency, it was very simple to make an electric clock that would keep accurate and synchronized TIME at ANY point in a power system. They set up governance, so that, at the end of each 24 hours, they had averaged exactly 5184000 cycles in a given 24 hour period. Realize that an AC power 'grid' has a generator at one end of a line, that's connected to loads along a line, and that's conected to another line, going in another direction, to more loads, and more generators... all the generators are spinning TOGETHER, and pushing power on the same line. The LOAD limits frequency- a generator must be strong enough to push the WHOLE LOAD, if it is going to increase the line frequency, but to do so, the generator must be strong enough to take the load, which is effectively infinite (at least, in the perspective of a generating plant), so it cannot go 'faster' than the line frequency. it's very clever... And this is why your old fashioned synchronous motor-type electric clock was always correct, as long as the power didn't go out. Westinghouse's building clocks, railway clocks, signalling timers... all used that line voltage not only as power, but as a frequency standard for time-division.
Hi, I wanted to check in again after letting this motor sit for so long. Things were very busy at the machine shop where I took the worn shaft and bearings. I also went overseas for work and was unable to follow up with them about this small job repairing the shaft.
Finally the shaft was completed! I also had cleaned and re-varnished the stator, in preparation for getting use. Some of the slot covers were pushed up and rubbing the rotor, even with the shaft repaired. I buffed them down so that nothing would rub. The rotor also had grime and rust, so it got cleaned. I modified the bearings slightly; by adding a copper pin. This is to prevent the oiling ring from jumping out of the bearing slot and failing to oil the shaft. I didn't take a picture but it is in the video. With a new coat of paint, it's looking pretty neat, even if I do say so myself. So - what to do with it? I love antique machinery but I also like to be able to put it to use. In this case, I don't need to run any equipment with a 10 HP motor.... but I do have a three phase converter which is getting really tired. Time to build a new 3-phase converter! Virtually all of the parts used were salvaged parts. I built it into a wood base with wheels, so as to make it semi-portable LOL! The 3-phase outlet and test cord. There's a lot in the box... I continued the motor restoration videos, with the shaft and bearing reinstallation. [TUBE]-p0qtqYTiGQ[/TUBE] There is a link to the phase converter build at the end of the motor repair videos. If it doesn't appear, you can copy this link to the first of the phase converter build videos:
I'm sorry, in advance, for the rant in the videos. Just a little irritated with the trolls these days. :) This motor has so much iron and copper in it, that it makes an amazing phase converter. Well more potent than expected. Could start another more modern 10 HP motor "effortlessly" and even was able to start a 20 HP. Thanks for the interest and hopefully you've enjoyed seeing this yard decoration be put to use again! Sincerely, David |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8074 |
Very well done! That is neat! Kind of rewarding isn't it?
Thank you Steve! Yes it is very rewarding indeed.
exSW ![]() Orange Level ![]() Joined: 21 Jul 2017 Location: Pennsylvania Points: 914 |
Fascinating thread . Thank you.
Learning AC...slowly
You're welcome. Glad it was interesting to you! Now I have to get some more antique 3-phase equipment to run with it LOL! :)
I certainly wish I understood electricity like you guys.
