190xt engine rebuilf |
Jds40004
Bronze Level Joined: 15 Mar 2017 Location: Kentucky Points: 6 |
Posted: 13 Oct 2017 at 3:48pm |
Getting ready to rebuild the engine in this tractor over the winter. What is the largest bore the block can go to and still be reliable? It's largest load will be a round baler and only 20 roles a year.
Have no problems spending the extra money to make it stouter just plan on doing it once. Then it should out last me. I've tried looking for parts or a supplier for them but can't find anything Trying to plan it out before I start on it. Will be balanced, fire ringed and copper head gasket. Thanks James |
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7231 |
If your largest load is a round baler, why do you want to spend more money for power that you do not need?
Get a good engine kit from a reputable place (NOT e-bay). Balancing, fire rings and copper head gaskets are not needed for a regular farm tractor doing regular farm tasks. Different story if you are going to be doing hardcore pulling with it. I did a major rebuild on mine last year. Bottom end, valve kit, camshaft bushings (often overlooked). Pretty much everything was from Reliance. Had my neighbor do the rebuilding, he is very thorough! The 301 is already a very reliable engine with no known major problems. Don't waste your money on the "upgrades" you have mentioned. Focus on the engine as a whole. Look at everything! If you are not sure of something, don't overlook it -replace it. It will outlive you providing you do not cut corners on the rebuild. |
Jds40004
I've never put an engine back stock my entire life. I like one to have way more than it should. Point is I'll only be rebuilding this engine once so spending money to make it more isn't an issue
The real reason for making it bigger is because I want to not because I need to. I was just looking for some one that had been into them to see what bore was obtainable before having problems with counterbores |
AaronSEIA
Orange Level Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2537 |
You have way more than you need now for what you do with it. If you want more, add a second turbo. I know of several 301 AC's running twins in a 410 class pulling and they do just fine at 315 cubes. But...they leave the line turning 5,000 rpm and making 80+ lbs of boost.
AaronSEIA |
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7970 |
John Deere 404 engine sleeves and pistons can be used in a 301 after the block has been machined to accept them getting around 360 cubic inches
Beirnesy
Orange Level Joined: 30 Jun 2012 Location: Mid Western Ont Points: 351 |
may I ask what connecting rods and piston pins would be used in this combo?
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
Jds40004
Thanks Doug. That's what I was looking for. No engine shops around here are familiar with allis
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4793 |
Hopefully ops heads will chime in, but this project would be perfect for his 341 sleeves and pistons. Using the aftermarket sleeves he has custom made, they go right in the block with no machining. I have drop on fire rings and mls head gaskets here for 301, and several others too. I've got heavy duty pushrods in stock as well. I can see a tweaked up fuel pump, improved injectors, and an S200 turbo rounding out the package! Great build until you see how much it would cost lol! Then you'll have to take it pulling lol!
Orange Level Access Joined: 12 Sep 2009 Points: 19645 |
A copper head gasket for a farm tractor??... bad idea...will leak water and oil everywhere in time. A larger bore on a farm use tractor just to say you have a larger bore?? ...another pretty bad idea...you can develop enough power with the stock bore to rip everything behind it to shreds on the farm, and the engine won't ever break a sweat or let you down. Sealed Power pistons and sleeves I believe are the old M&W design and are a step up in cold starting and run real nice I've been told. I like the idea of twin-turbo's a whole lot better.
Jds40004
Perkins uses copper gaskets on a lot of industrial engines as did caterpillar now it's mls. I'm fine with either style.
I agree with it being over kill. I'd rather have more displacement if it doesn't cost a huge difference in price. I'm only building it once Fuel wise it'll get sent to you Ed. Don't need huge smoke just want response I was thinking hx35 on charger. Small enough to spool quick. Not sure difference between it and s200? Will send cam for a regrind. May try to find a roller as I doubt there will be any zinc left in diesel oil in 10 years and hate idea of wiping cam out I know it won't be cheap to build. Figuring 2000 in machine work alone. It's going to be a toy anyway |
WF owner
Orange Level Joined: 12 May 2013 Location: Bombay NY Points: 4442 |
I'm probably just dreaming Ed, but how much horsepower do you think this combo would put out and a ballpark figure?
injpumpEd
Depends how far one wants to go with pump and injectors. 200-250 is pretty easy without a lot of custom work. I've got several setups like that out running around, mainly going down the pulling track, and light hay work etc.
