Hd 20 needing a blower and shaft |
Post Reply | Page 12> |
rickv57
Silver Level Joined: 15 Jan 2016 Location: 64024 Points: 199 |
Posted: 18 Apr 2017 at 10:29am |
Could you give me a call on your HD 20 parts 816 615 3699 thanks Rick
rickv57
I sure could use some parts can somebody hook me up with his fellow thanks
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29714 |
If are access plugs/covers on the end covers get them off and pour/spray/oil can a load of oil into them, better than zip.
Brent.eggers
Silver Level Joined: 29 Oct 2016 Location: Parsons, Kansas Points: 78 |
All this is true & yes I some how pulled a dumb dumb & didn't think of splashing oil let alone even a little wd40 on any of it. But don't plan on pulling that heavy sucker back off to do it
Cranking it with in no fuel would be better than the air flaps closed as the blower seals if they should leak could supply enough fuel to make it run as well will be enough air in the engine to make it start.
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8035 |
coulda oiled before you put it on...doubt you hurt anything by just firing up and make oil pressure
Brent.eggers
The motor has ran in the last 6 or so mothers by he previous owner it's mainly the blower I would like lubed. Before I start it I think I'm thinking they get oil from not only the supply line but the drive line side as well I'm guessing is more of a splashing system all I no is the blower is rebuilt but like 40 years old rebuilt. So it's basically dry. I think once I go to start it it has a drain back so I'm shure I will have to crank it a bit. I have an old piston hand pump that's old I pop free old Rosa master Injection pump plungers free with & pressure lube with so I won't have to use air over liquid. I guess I'm more conserned with the volume it might take to get it lubed if I just tap in to the block it may just go to the main or rods & never get to the blower. Wonder if cranking it. With the air kills shut down until I belive it is lubed would work best
Any way or form to get oil on the engine before turning it over would be a great idea. We used to use a old small air tank off a freight liner, capped or plugged everything we did not need, sent at least three quarts into the main rifling on big engines just to get a head start. Any small air tank, even a pressure bubble from a crap shop like Harbor Freight will work, just have to fill slowly thru whatever opening you can find, add a nylon tube(like air brake line) and fittings to the engine.
ACjack
Silver Level Joined: 13 Sep 2014 Location: Peoria, Arizona Points: 274 |
Definitely pressure lube the engine before trying to fire it up.
Brent.eggers
I got one of the 3 blowers on & it's a old newly rebuilt one & the shaft Ac Mel sent seems like it's going to work. I'm currently waiting on a good 50 degre out day to try & fire her up I'm thinking it might be best. I'm not shure. How long it will take for that blower to get oil from the pump? Wonder if I should pressure lub the whole thing first
Brent.eggers
I feel like a kid waiting on ol Saint Nick to bring me a bulldozer down the chimney. Lol of coarse it will be this blower shaft
AC Mel
Orange Level Access Joined: 23 Jan 2010 Location: N.Ca. Points: 1099 |
Ok, we dug into our HD20 carcasses and got a good blower shaft and locking clip to send out to AC Guru Brent. Put it in mail this morning. So we'll need to hold his feet to the fire to get some HD 20 action pictures
Brent.eggers
I have 3 I think two are rebuilt. I'm thinking one rebuilt one will fit right on. The other rebuilt one takes as a guess a 12 1/2 inch shaft verses the what I would call a 14 inch shaft that is stock the other blower is absolutely used & im thinking it may have need some attention. Bob was an assume man he gave me a parts book for the 20 & a hd 19 operators manual. He also gave me a Euclid 6-110 book maintenance manual. He is a great fellow he had some some parts I wish I had but some one else may need them worse than me. I tried calling u Mel it wasn't going. Through yesterday I will take some pics today. Mel when u take that shaft out I need those little clips that hold the shat from moveing back & forth I lost one & the other one I put up lost its self they shure are excape artists in the grass
AC Mel
Brent, Copy that,did you get any blower pictures from Nebraska? to post up? I'll plan on getting one apart to see. We'll talk again.
Brent.eggers
Ok so I'm on my way home from Nebraska i a couple blower options so I think I have that covered but I will need a blower drive shaft Ac. Mel
Brent.eggers
I'm pretty excited to meet Bob & I'm shure he will teach me something I never new. I'm just afraid il get their & want to buy moreAllis stuff than I really need lol. I'm going to temp to meet up saterday to see what he's got.
dpower
Orange Level Joined: 11 Sep 2009 Location: Madison Ne Points: 1575 |
Not only did Bob work at an AC dealer he and his friend started a business redoing those GM motors that were on Doffin Grinder mixers mounted on trucks so hopefully he does have the parts for you.
TramwayGuy
Orange Level Access Joined: 19 Jan 2010 Location: Northern NY Points: 11263 |
I am pretty sure that the shaft was made so as to break to prevent worse damage to the gear train.
Brent.eggers
Oh I darn shure will I'm shure il be needing something. This site is awesome too
CAL(KS)
Orange Level Joined: 18 Sep 2009 Location: Chapman, KS Points: 3746 |
good news. keep us posted
Brent.eggers
I talked to an 80 year old fella last night in Nebraska. Named Bob Witzel. He seemed very sharp. He said he thinks he has a good blower & shaft said he would get back with me today gonna keep my fingers crossed I wonder if someone had a hd-19. & a 20 & cross bred them I have most of the stuf I think I could slide it back together enough to play & save I need a u joint cap or u joint & theiers a berring out in the front of the I think it's the transmission. Think I will try putting it together this winter. I'm shure il be on hear then.
JC-WI
Orange Level Access Joined: 11 Sep 2009 Location: wisconsin Points: 33667 |
Wonder if Brents second crawler isn't an HD19, the had those 6-71 in them...
And I do not know where theres a 6-110 either... seen a few sold over the years... probably long gone to scrap eons ago now. |
I would think a good machine shop could build one and get it heat treated too
Brent.eggers
Still no real news the guy that had 4 6 110 engines turns out two are 671s. The other twwoo might be 6 110 but way shorter valve covers blower looks differant so I'm. Still hoping & praying evever night that Ac Mel can save. The day or someone can help.
Brent.eggers
I called them to a few weeks ago their site showed they have parts & such but the main man said its newer stuff & doesn't fit. I was like ok so why do you advertise. U have 6 110 parts. Anyways I they didn't help any. Their web site got me excited just for a let down.
CAL(KS)
Brent.eggers
I just called them they couldn't even direct me to anyone
CAL(KS)
DID YOU TRY GENERAL GEAR IN IDAHO?
Brent.eggers
Shure would ever hurts to call might learn something too.
dpower
my uncle was parts manager for over 30 years at Fehrs Allis Chalmers Equipment(Road Builders) in Omaha NE. He also parted out different machines over the years. You want his number to see if he would have parts or know some close in Nebraska??
