Model B cam bearing holes |
00transamnh
Silver Level Joined: 15 Sep 2016 Location: Maine Points: 55 |
Posted: 09 Oct 2016 at 2:36pm |
Hey folks,
I have a 1940 Model b that I am rebuilding the engine on and need some expertise. I have new cam bearings installed in the block and when in position the oil holes between the block and cam bearings do not line up. Approximately 1/2 the hole is covered by the bearings at all 3 locations. Is this normal or do I have cam bearings wirh holes that are off location? I assume what is exposed of the oil hole is sufficient for oiling the cam but want to make sure |
00transamnh
Bump-engine build on hold. Any experience with this out there?
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4447 |
just run a drill bit in to open up the holes to match the block.
Dick L
The holes are to oil the main Bearings. They need to be open.
