Forklift L80-FPL80-24 ? |
Post Reply |
jpi72
Bronze Level Joined: 27 Jul 2019 Location: Hudson, Iowa Points: 24 |
Posted: 27 Oct 2022 at 8:56pm |
An AC forklift is coming for sale. I have not seen it yet, but this is the numbers L80-FPL80-24. Is the 80 for 80 horsepower? What does FPL stand for?
I realize parts will be an issue. I am assuming that it is an engine that had other uses. Any help would be appreciated. Joel
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78005 |
i think the 80 means 8,000 pound lift... or about 13,000 pound machine.
i though an FL was "Forktrk liquid propane" ........ and FP was "petrol"... or gasoline. Edited by steve(ill) - 27 Oct 2022 at 9:44pm |
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21559 |
yes, 80 means 8,000 pound lift,probably good for a tad more too !! FPD means a diesel powered,THAT I KNOW as I have an FPD50-24-2PS 2PS might mean 2 speed,automatic. I also know that the driveshaft U-joints( double Carden (?) were never greased. It needs to be replaced ( no needles...still works though, shhh) Not too sure HOW you'ld get a 13,000# beastie up off the ground for service though... www.liberatedmanuals.com has 1,000s of manuals, if you put allis 8000 into the 'search' option it'll narrow it down to maybe 20-50, then download 'this might be it',open, read, try again....
DaveKamp
Orange Level Access Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 5642 |
Tilt the mast full back. Place a big wood block under the base of the mast. Tilt the mast full forward. Tires will lift off the ground, place blocks under tires. Tilt mast back and repeat.
Joe(TX)
Orange Level Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
I think the P means pneumatic tire.
Post Reply | |
