Florida bridge failure |
Post Reply |
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41217 |
Posted: 17 Mar 2018 at 9:38am |
"Challenges are what make life interesting; overcoming them is what makes life meaningful." |
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7946 |
What is the deal with that,, something went horribly wrong
thendrix
Orange Level Joined: 04 Feb 2013 Location: Fairmount GA Points: 4740 |
I heard on the radio yesterday they erected the bridge on Saturday then went to tighten the cables a few days later and down it went. Surely this wasn't the case but I hope it wasn't somebody took a cable loose prematurely and down it went. I can't imagine trying to live with that
tadams(OH)
Orange Level Access Joined: 17 Sep 2009 Location: Jeromesville, O Points: 9680 |
Today they are saying someone seen cracks in it a couple days ago
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21549 |
I'd have ALL the 'engineers' who signed off on it up on murder charges. And I'm going EASY on them !!! With today's 'technology' and computers there is ZERO EXCUSE for those people dying !! A WHOLE lot of people need to be held ACCOUNTABLE.
Alberta Phil
Orange Level Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3657 |
We had a road bridge built here a couple of years ago to replace a perfectly adequate one that was over 100 years old. The new one collapsed before they even got it finished and it had to be re-designed and done again! I'm still afraid to drive over it or under it!!!
Orange Blood
Orange Level Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Hang tight there Jay. Please remember the construction crew was performing post tensioning activities, "AT the TIME of the collapse". Something tells me we are going to find out, the work crew had no clue what they were doing, or had dialed in incorrect values. All my years in construction have taught me one thing......Communication ends with the first person told, and the lowly person performing the actual work, has no idea of the requirements.
Still in use:
Richardmo
Orange Level Access Joined: 12 Sep 2009 Location: Rolla mo. Points: 1735 |
Why did they have people driving under it, while working on it, would be the question needs to answered.
WF owner
Orange Level Joined: 12 May 2013 Location: Bombay NY Points: 4415 |
In New York State, anything that involves a state highway, construction or maintenance is overseen by (NYSDOT) state inspectors. I know that government doesn't always do things better than the private sector, but in this case, I, personally, think it's a better way to go. State inspectors don't care about costs. I sure hope someone didn't take shortcuts to save a few dollars on the construction of this bridge.
I'm sorry, but I have to respectfully disagree with you. Any 100 year old highway structure, especially in climates where there is snow, and thus anti-icing chemicals used, has outlived it's structural life (by far!!!). In my over 30 years of experience in highway maintenance, I've seen many bridges that were built in the 1950's that were structurally deteriorated to the point where they were unsafe. Some had weight restrictions imposed and others were permanently closed. Some that remained open, scared me, after I had been under them and saw the shape they were in.
FloydKS
Orange Level Joined: 12 Sep 2009 Location: S E Kansas Points: 7913 |
My thoughts are the same as Richarmo...why were they "doing stuff" when traffic is around...under...
jaybmiller
I was under the impression this 'high tech' bridge was built offsite ,then hauled in, lifted,rotated and sat onto the 2 support columns(though not secured to them). If this is correct, the bridge is nothing more than a simple beam, a dang heavy one, especially for just people to walk on. I'm thinking it 'should' have already been 'post tensioned' or whatever the jargon is to make it stong. Yeesh they somehow moved it from 'A' to 'B' so perhaps it wasn't hauled properly(say 3 point support((ends and middle)) and something went wrong inside it. I've seen far larger pieces made and installed and those bridges are still standing. Since the media here changes feet to metres( usually wrong) or they mix the two, reports here are confusing but again, I'm led to believe this thing was 100' long and weighed 950 tons ! That alone sounds bad to me as the two end columns need to support 500 tons each. Have to wonder how deep they drilled to find solid bedrock. Another isssue I saw was the uncoated rebar. I don't know how salty the air is there,but I KNOW up here CaCl used in winter EATS rebar and destroys bridges. Water + salt = saltwater, seeps into porus concrete, finds rebar, turns steel into rust and expands making bigger cracks, makes it worse, repeats, then gee the bridge failed .... 3 local ones here have been 'rebuilt' since 1967 yet the 100 year old dam took the jerks 2 weeks to break apart!
I'd like to know if there is a real 'test' bridge somewhere of this design, that's been erected and monitored, or if this was approved solely based upon a 'computer simulation'. If only a simulation, then I understand exactly WHY it failed. I deal with simulators everyday and NONE can properly simulate the REAL World, NONE. Someone has to be made accountable..this was NOT an accident. |
shameless dude
Orange Level Joined: 10 Apr 2017 Location: east NE Points: 13611 |
the walk bridge cost was 15 and a half million $$$. "new and improved" didn't help on this one!
WF owner
There is no alternative but to build bridges in major metropolitan areas using ABC (Accelerated Bridge Construction). Have you ever driven in Miami at rush hours? It is a giant parking lot with all highways open. Imagine closing down a major highway. That's why most of their construction is done at night.
Bridges are built all the time using ABC. Most of the newer major bridges around New York City (and I'm sure other major cities) are built using ABC. Some of these bridges are multi-lane and even multi-level. My point is that much bigger bridges than this pedestrian bridge are built using ABC and set in place on weekends or nights when traffic is diminished. My bet is, when the investigation is complete, it will come out that someone cut corners, either on materials (concrete, reinforcing steel, cable, etc.) or someone did not follow proper engineering specifications or practices, probably in the name of increasing profits.
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77976 |
I heard the bridge was 950 tons and 175 ft long.. There is suppose to be a TOWER at one end and cables run down to the bridge center to support it UPWARD........ that was not installed "YET".......... With 8 lanes of traffic, I think there should have been a BASE installed in the median between the 4 lanes each way so you were spanning just 90 ft... Could have been removed AFTER the tower and cables were installed....... but WHY not leave a center support forever ??
Edited by steve(ill) - 18 Mar 2018 at 12:05am |
shameless dude
cuz someone would hit the center support and prolly gits killed! we always observed at our office, that if there was anything close to a roadway....it's gonna get hit by someone in a vehicle! one really weird accident comes to mind, the only power pole in a several acre area on top of a steep embankment, a van went off the road, climbed the embankment (about 70 ft on about a 45 degree angle) and hit that pole!
desertjoe
Orange Level Access Joined: 23 Sep 2013 Location: New mexico Points: 13361 |
Well,,,I must be one of those people ole Shameless is talkin bout,,,,, they just finished up a "Total Renovation" on the local KFC in town and they put in a NEW 6"X6" metal post where you have to drive around it to get to the pay window,,,and,,,,and,,,you guessed it,,,,they painted the blame thing BLACK,,,!! I almost hit the dang thing the other night cause I did not see it till almost right on top of it,!! The night manager said she had nothing to do with it being black,,I told her I would bring some white paint next time I go by,,, |
shameless dude
the local phone company buried their line past a buddies driveway, and they put one of them above ground junction boxes right beside the driveway. he went in and told them they gotta move it. they said it had to be there! so when he pulled out of his driveway with his big disk, guess what gots hit and bent to chit? they moved it!
mdm1
Orange Level Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2599 |
The same company designed two local bridges. Both cross the Mississippi river.
Ray54
Orange Level Access Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4370 |
The neighbors with a big cattle ranch have had a contractor put a lot of new oil field pipe H braces in the fences along the county road. Being thrifty they did not put in new wire or T post. The daughter calls the pipe posts "car magnets". Seems every car that hits the fence always bends a pipe over.
DiyDave
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50616 |
[TUBE]Ucflj-MsJBI[/TUBE]
Post Reply | |
