Flashing the GEN |
Post Reply |
DonDittmar
Orange Level Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2476 |
Posted: 02 Nov 2022 at 6:27am |
OK, So after you pull an old DC generator off or have the battery unhooked for extended periods of time, you have to "flash" the GEN at the VR to get it back charging again. In technical terms, what is actually happening when you do this? Are you providing that initial residual magnetism?
All you electrical engineer guys, this is your time to shine LOL
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start |
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78002 |
You buy a regulator that is positive or negative ground... You have to match the generator to the regulator... The generator can charge either way depending on the residual magnetism inside... With the key off, you touch the BAT and GEN or "A" terminals of the regulator to send the BAT signal to the generator.. That sets the magnetism inside so the generator knows which way to charge............... at least thats the way i was taught.
Generators should retain their magnetism when off for some period of time.. If this is a old generator or has set for months, it is a good idea to FLASH or POLARIZE .. normally do this when you get a new regulator or do bench overhaul work.
DonDittmar
Thats kind of what I thought too, but I am in the process of making an educational video and I wanted to be sure before I told someone the wrong information
Flyer
Silver Level Access Joined: 11 Sep 2009 Location: TN Points: 456 |
A generator that has been used recently will have enough residual magnetism in the armature to initiate voltage output when the generator starts rotating. I think the term is "remanence". A generator that has been off for an extended period (or has never been in service) will no longer have enough magnetism to start the process so it has to be initiated from an external source.
Edited by Flyer - 03 Nov 2022 at 5:49am |
An optimist sees the glass as half full. The pessimist sees the glass as half empty. The engineer sees a glass with double the required capacity.
Les Kerf
Orange Level Joined: 08 May 2020 Location: Idaho Points: 632 |
Yup. Flashing the generator does two things: it establishes the residual magnetism, and also establishes the polarity of the residual magnetism.
I was just a lad back in the 1960's and I clearly recall my Dad and other adult men voicing their distrust of those newfangled alternators because you could not push-start a dead battery vehicle equipped with an alternator like you could a vehicle that had a generator. |
mdm1
Orange Level Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2599 |
I remember it by Boy to Girl but never to Female! Now if I could remember key off.
Post Reply | |
