f150 hauling cap. |
Post Reply | Page 12> |
TimCNY
Orange Level Joined: 15 Apr 2014 Location: Upstate NY Points: 1551 |
Posted: 14 Sep 2019 at 9:09am |
My F-350 dually 4X4 rated cargo in the bed is 5,500 lbs. The most I've ever had on it was 5,300. Only thing I noticed was that it rode as smooth as a Lincoln Town Car lol.
I use it a lot when hauling maple sap in a 325-gallon caged tote. When full, not counting the weight of the tote, there's roughly 2,760 lbs., nothing at all for my truck. But I know plenty of guys hauling sap in 275-gallon totes (if full, not counting tote weight around 2,335 lbs.) with half-ton Fords, Chebbies and Male Sheep I mean Rams and they squat something terrible. MANY complain of broken axles, broken springs, cracked frames - sure, some of that has to do with age, but it all boils down to STOOPIT. And yes, there are accidents and tickets waiting to happen. |
I need more than 200 characters for my "signature." I'd love to see that changed to 250!
shameless dude
Orange Level Joined: 10 Apr 2017 Location: east NE Points: 13611 |
(poke,poke)
shameless dude
Dennis...less than 10 miles? make 2 trips if'n yer scared!
Mactractor
Orange Level Access Joined: 20 Jun 2011 Location: New Zealand Points: 652 |
I'm hearin ya there Dave. I shoulda done it a long time back
DMiller
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29776 |
Already decided and have noted on here should I replace my '99 F250 SD it will be with a class 6 or 7 actual truck. Tired of repairing as things disintegrate on the too light for what I am doing to it trucks.
Dennis(IA)
Silver Level Joined: 12 Sep 2009 Location: IOWA Points: 356 |
Yes Tom you are correct, I will use my 20' flat bed trailer. Not as handy backing into his driveway, but it will hold 1 ton no problem. He said that he has a BIG tarp and we will lay that down first then fold it over the hot asphalt.
Mactractor
Done a lot of serious vehicle overloading over the years and got away with it, but that run came to an end when I tried to haul home a tractor on a hired flat bed trailer behind a Chevy diesel 1500. The 4L80E's torque converter transfered that much extra heat to the engine, when head gasket blew, pressure through cooling system blew a fist size hole outa the plastic radiator end tank. (this one's not to wind Shameless up about Chevy's) Got a medium duty truck now.
200Tom1
Orange Level Joined: 03 Jun 2019 Location: Iowa Points: 1158 |
Do yourself a big favor. Rent a trailer. While working at the car dealership, I've seen too many fords around that year with the rear spring mounts broken off at the frame. Load on trailer pretty much over the trailer axles.
shameless dude
my old motto was: if it fits, it hauls! can't do that with most of the new ones nowadays. even tho I still do try it.
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78231 |
and years ago I had a 3/4 ton that had a bed capacity of 3800# ( almost 2 tons ). all depends on how it is equipped.
All depends on how the truck is equipped and geared. Like Ken said, some at the TOP end have a load capacity of 2000 or 2100 pounds... The "normal" F150 will have a rating of 1500- 1600 pounds capacity... If you get the lightest duty with the high gear ratios to get the highest milage, they are the 1000 pound capacity units. .... A standard cab with the 8 ft bed and HEAVY shocks / tires / etc can be had for 2000 pound capacity....... You get a CREW or 4 x 4, or short bed and the numbers drop into the 15-1600 range.
I have a 2013 CREW with short bed and 4 x 4 and it is rated just over 1500 pounds... I do that all day long.
john(MI)
Orange Level Joined: 12 Sep 2009 Location: SE MI Points: 9263 |
I had one of them F150 PU once with a cap on the back. I went and picked up a 500 pound load of parrots one time. I had to have my buddy run along side with a baseball bat whacking the truck to keep them flying!
DMiller
Three issues with later model Half Tons, suspension less than the old Station Wagons, frames are tin foil and twist/roll like softened spaghetti, axles in back with ring and pinion as well ball joints/control arms up front designed for Ride not carry. Engines and transmissions can do the work just the remaining truck is not much truck.
Ken(MI)
Orange Level Joined: 14 Sep 2009 Location: Lansing, MI Points: 618 |
I owned a few F150's, last real one was a 1994, single cab with a GVW of 6,600 lbs, it would handle a ton easily, I hauled with it a lot, kept it for nine years and 150,000 miles, replaced the rear springs at 100,000, which is about normal life for the springs of a working pickup. The last actual F150 I owned was a 2014 crewcab, that was only good for hauling potato chips or ping pong balls. I put a 800 LB. welder in the back of it once and it drove like a boat. I kept that one three years and traded it for a Ram 2500. Pretty sure I'm done with half tons for as long as I want to actually use a truck for more than a grocery getter. I agree with the above, considering the age of your truck, I would decline to help.
Ray54
Orange Level Access Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4374 |
Please for give me for derailing. Joe there is a song about O'l Shamers but cannot remember the name. Something about driving my International Harvester combine down the highway. |
Tbone95
Orange Level Access Joined: 31 Aug 2012 Location: Michigan Points: 11430 |
Years ago, I hauled 1500 pounds of stones in a 6 year old 1/2 ton. Only a few miles, but that was DUMB. Too much, probably by 300. Not all 1/2 tons are the same capacity, but none haul that much. Don’t do it.
Or, just make a joke out of it and pray you don’t actually hurt someone and that your luck and charm will carry you through. |
Dennis(IA)
I told the guy I could haul a ton on my tilt bed trailer, no problem. My wife said what the h*##@@ you getting yourself into now!
Dennis(IA)
I think that was a side delivery rake. You don't realize how wide some machines are until you have to haul one on the road, through town.
desertjoe
Orange Level Access Joined: 23 Sep 2013 Location: New mexico Points: 13362 |
Well,,,,"I Remember The Story",,,,cause I laughed and laughed at the thought of this farmer drivin up and down all them farm and market roads and alleys with thet silly Dennis The Menace grin on his face snickerin all the way,,,,,,
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4440 |
Hauling a ton on a 1/2 ton truck is an accident and lawsuit waiting to happen. The “Oh it’s just around the corner” doesn’t cut it anymore. There are more TV ads for ambulance chasing lawyers on our local channels than anything else. Truckers need the rates they charge because of this. Are you willing to give everything you own to a blood sucking leech? |
If you can't make it GO... make it SHINY |
shameless dude
the last combine I bought, I took it right thru the middle of Omaha...and it really torqued off a lot of city bots! did I care? NOOOOOOOOO! I've taken lots of equipment thru lots of places...sometimes it being the fastest route and sometimes I didn't wanna gits caught!
desertjoe
,,,you must have lots of backroads,,,right,,,?? Say,,,,that right there reminds me of a story YOU told on here a long time ago,, bout you buyin a combine or some such farm equipment from a fellar way down south of you and,,,,and,,,roadin (hidin is better word) that combine over all the back roads, alleys and deserted farm fields to finally get it home,,,,,you remember that,,,????
shameless dude
load it on a Chevy 1/2 ton and go! not even gonna tell you how much I put on an S-10
Scott B
Orange Level Joined: 14 Sep 2013 Location: Kansas City Points: 1002 |
I think of it a bit differently......what do you say to the family you crash into when your brakes fail, a tire bursts or axle breaks and the load goes everywhere.
I always plan conservatively be it my truck, trailer or combination of the two. Too many people say “ it’s just an old truck. Load it up” |
D17 Series 1
Allis B- 1939 Allis B- 1945 |
a half ton truck normally holds more than 1000 pounds... Most are in the 1500 pound range.... 2000 pounds on a 20 year old truck would be pushing it. I haul 12-1500 in a 2013 quite often.
Dennis(IA)
Thanks, your input confirmed my answer, I already told him no, but I would check it out.
john(MI)
Gonna be a bitch jacking it up to change a tire! Wouldn't do it with my truck and mine is a Toyota Tundra. Just put it on a trailer, and save your truck. Of course if you are looking for a good excuse to get a new truck . . . have at it!
Hubert (Ga)engine7
Orange Level Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6152 |
X2 on the trailer. That way you won't have your truck committed and can go do something else while your friend unloads the trailer. I have been guilty of hauling way too much on my older F150's and gotten away with it but that was when I was young and foolish. Now that I am old and stupid at least I know better.
TimCNY
Last time I needed to know back when I had an F150 (I have a 350 dually now), I just called the local dealer and the service guy looked it up. Worth the trouble, to avoid trouble. And 10 miles doesn't mean much - hills? Rough road? Makes a difference especially when they're that old. Actually with the way they use salt around here for all 9 months of winter each year, that wouldn't be "old," that'd be, "scrapped it 5 years ago. right after the frame broke in 2."
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21639 |
TWO trips !!! or use a trailer...a small tandem dump would be ideal( like HOW ya goin get that stuff OUT of the bed ?? ) Your truck, like mine is a 1/2ton pickup... 1,000# max( which includes gas and driver and whatever else is onboard...so maybe 700# payload.. Your springs like mine are 20+ years old, you need to treat them nice !! I have a spare set 'somewhere' in the shop... hmm maybe 3 trips...would be better ! I always take my trailer when a 'friend' asks...cheaper/easier to fix it than my '97 F150 ! Trailer is good for 4200# and I've hauled 4500# ONCE...stopping was fun..but slow and steady got me there. Beside I can leave it,full, and go home if I want to..HE can unload Jay
Edited by jaybmiller - 10 Sep 2019 at 5:43pm |
