ditch witch v30 crowd lever? |
Post Reply |
Mrgoodwrench
Orange Level Joined: 03 Apr 2011 Location: CHICORA PA Points: 2081 |
Posted: 27 Nov 2012 at 9:05pm |
last winter we picked up a v30 for the farm. seems to work good haven't used it too much. there it a hyd lever labled "crowd" but it doesn't seem to do anything. does anyone know what this is for?
Allen Dilg
Orange Level Joined: 12 Sep 2009 Location: NE IL Points: 820 |
Hello Mr Goodwrench Haven't worked on any trenchers in a very long time Creep and crowd should be the same. There should be a hyd flow control valve in that line that adjusts crowd speed, and the crowd lever to start and stop movement also it should reverse direction. Good Luck
Mrgoodwrench
i assume you mean reverse the cutter ...i thought that but it must not work...guess i need a operators manual
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41213 |
http://ditchwitchv30.informationconcerning.com/
"Challenges are what make life interesting; overcoming them is what makes life meaningful." |
Post Reply | |
