Diesel mechanic help needed |
Post Reply |
Thad in AR.
Orange Level Access Joined: 12 Sep 2009 Location: Arkansas Points: 9275 |
Posted: 07 Jun 2019 at 5:38pm |
Working on my mothers 1215 Ford tractor again. I have it running well now but it continues to smoke diesel smoke. It was loading up so much it would almost lock up. Now it isn’t that bad but still smoking. I drained the diesel and put in new and added diesel clean. It starts quick and runs well. Doesn’t seem to smoke at idle. I assume an injector is constantly leaking fuel in??? What else might this be?
DMiller
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29597 |
Ford used a CAV style injection pump, the NOZZLES are strictly end delivery devices that pop off at a desired pressure. If it is suspected a dribbler will need to find that hole(will be cold on start up on the exhaust) and pull that nozzle, swap with one of the other good ones. Problem remains in the original hole then there is internal engine issues or possible damage.
Thad in AR.
Thank you. That’s a good start. I’ll check exhaust port temp next time I start it to see if one heats up slow.👍 |
im4racin
Orange Level Joined: 12 Jun 2017 Location: Garrison ND Points: 842 |
Probably won’t see it with temps. Do you have any white smoke on start up? If so remove manifold and see what port is smoking then proceed with dmillers advice
Thad in AR.
It doesn’t smoke at all at start up. It has to run a few minutes before it starts to smoke. The only white smoke is when going from idle to full throttle. Then it’s whitish but still smells of raw diesel.
im4racin
That is a timing shift issue. You will need to take the pump off for rebuild or find some cleaner to run through it. Cummins sells a can of good stuff. Not sure what they call it but it's about a 3 gallon metal can that you run the engine on rather than mix in the fuel.
DiyDave
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50581 |
Check inj lines, and injectors, for double copper washers. If someone has been into it, before, putting 2 washers where there should be 1 can cause 1 or more cyls to be timed 2º or more off spec...
Thad in AR.
This thing sat for over 3 years but was running perfect before parked.
desertjoe
Orange Level Access Joined: 23 Sep 2013 Location: New mexico Points: 13360 |
Hey Thad,,,did you get your Mom's tractor figured out? I ain't ever worked on a diesel so I can't offer any help,,except that according to all the comments,,it is something that occurs AFTER some run time and not right soon at start up,,,,??
Thad in AR.
You are correct. No smoke until it runs a few minutes. It got much better than when I first got it going but still smokes diesel smoke at high rpms. |
DiyDave
If its a misfire, you can loosen the injectors, 1 at a time, and see if it makes a difference in the sound, or rpm. If you find its a particular injector, Say # 2, move #2 to #3 position, and try again. If it moves with the injector, problem solved. If not, you got pump problems...
Thad in AR.
Thanks Dave that makes perfect sense. Next time I start it I’ll give that a try. |
DMiller
The infamous ran fine when parked, Now Thad you oughta know better!!!
Edited by DMiller - 09 Jun 2019 at 7:26am |
chaskaduo
Orange Level Joined: 26 Nov 2016 Location: Twin Cities Points: 5203 |
But we all hate it when that happens.
Thad in AR.
Yes I should know better. LOL. Reminds me of an add for a gen 1 Cummins Dodge forsale. I looked at the pic and thought wow what a nice truck. Then read the add which says not the actual truck but this is what it could look like.😂😂 |
wide
Silver Level Joined: 29 Dec 2018 Location: north iowa Points: 169 |
If it's black smoke it might be a clogged air filter.
As it runs the restriction gets greater than at startup. I've always had good luck with diesel purge. for cleaning out pumps and injectors on the VWs. Bottle fed straight through the pump, not added to the tank. |
Thad in AR.
When I brought it home I removed and cleaned the air filter. Last time I started it I removed the filter and the smoke remained. |
Post Reply | |
