D-17 steel fuel line |
Post Reply |
Doug-KS
Orange Level Joined: 08 Jan 2013 Location: Wellsville, KS Points: 328 |
Posted: 24 Nov 2017 at 8:44am |
Does anyone know where to get a steel fuel line for a series 2 D-17? Or does anyone have a good used one they want to sell? I searched on line and I see them for a bunch of other models, but not D-17.
Stan R
Orange Level Access Joined: 03 Dec 2009 Location: MA Points: 943 |
Why not use steel brake line, bend to suit, with proper pipe connectors?
NICKMI
Orange Level Access Joined: 15 Sep 2009 Location: Greenville Points: 533 |
That's what I used on mine worked good need a brake line tool for the Ferrell
Hubert (Ga)engine7
Orange Level Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6126 |
Check with Steve in NJ -
11 Woodfield Road Andover, New Jersey 07821 Phone: (973) 632-5596 customcircuits@gmail.com Edited by Hubert (Ga)engine7 - 24 Nov 2017 at 10:41am |
john(MI)
Orange Level Joined: 12 Sep 2009 Location: SE MI Points: 9263 |
I just replaced mine, used steel brake line. Looks really nice!
gerkendave
Orange Level Joined: 08 Jul 2013 Location: York, Nebraska Points: 563 |
I used a soft copper tubing so you can hand form it from Napa. Then used compression fittings to attach both ends. Looks nice imo
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7204 |
Steel is harder to work with but better to use in this application. Copper does not stand up well with the vibration. |
Dusty MI
Orange Level Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5053 |
Compression fittings.
I have serviced a lot oil fired furnaces over the years. They use 3/8" soft copper to feed fuel oil from tank to gun, then 1/4 or 1/8" soft copper from pump to nozzle. I have found that using compression fittings with ferrels have a tendency to leak after they have been taken apart a couple of times. Flare fittings hold up much better. Dusty
Post Reply | |
