D-17 Series 3 Value |
Post Reply |
Zyta
Orange Level Joined: 19 Jan 2010 Location: Ontario Points: 238 |
Posted: 09 Feb 2011 at 4:49pm |
Whats the value of good running straight tractor with good tin work Series 3 with power steering.
Did all the series 3's have power steering? did a series 17 have any advancements over the previous series? can add factory three point hitch off later series 17's or any other later Allis. Appreciate your feedback.
Claus
Orange Level Joined: 09 Dec 2009 Location: Hebron In Points: 1150 |
I sold my Grandfather's 1964 in 2007 with the plow for $4,000.00 The tractor was very nice but I always thought that was top dollar for the set, it had power steering.
wheatbreeder
Orange Level Joined: 12 Sep 2009 Location: Harrow, Ontario Points: 580 |
Power steering was an option series 4 is the same as a 170
Morley
Farm stuff 8050,6690,175,F2,5050,WD
Pat the Plumber CIL
Orange Level Joined: 11 Sep 2009 Location: Springfield,Il Points: 4684 |
I believe that when the Ser III came out Power steering was standard,have never seen a Ser III without power steering.Our 59 Ser I we had on farm as kid is only D-17 I ever saw without it.
Do not believe a factory 3 pt off of a Ser IV will bolt on a Ser III or earlier.Different rear end and hydraulics.All series before IV have to have an aftermarket setup. Edited by Pat the Plumber CIL - 09 Feb 2011 at 6:35pm |
1964 D-17 SIV 3 Pt.WF,1964 D-15 Ser II 3pt.WF ,1960 D-17 SI NF,1956 WD 45 WF. |
Pat the Plumber CIL
Learn something new every day.Never saw a newer D-17 without PS but Wheatbreeder if you say so.Sure would have thought it would be standard.Who would order a 170 without it?
Zyta
Thanks good information. I thought I had heard the back side factory three point of the later series would fit. So does a series 3 have live PTO or again is it just by uitlizing the hand clutch?
Pat the Plumber CIL
Ser IV has live hydraulics but the PTO is the same as earlier ser.
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22810 |
All 17's have live PTO, none had independent PTO. Claus, I remember when you advertised that tractor on the old forum. I sure wish I coulda come up with the coin at the time.
Claus
This is not true, the Series IV still on the farm has a power steering pump, my Dad's white strip 170 drives the power steering from the side hydraulic pump. My black stripe 170 drive the power steering from the front hydraulic pump. |
wheatbreeder
I stand corrected I might all series 4 had power steering as the 170 is the same as series 4 with new tin
Morley |
Orange Level Access Joined: 12 Sep 2009 Points: 19572 |
I have a piece of D17 series 4 literature dated September 1964.....Optional equipment: Deluxe seat.....Power steering.....Operation meter (tach)....Air filter indicator.....horn......3-spool hyd valve.........break away and non-breakaway hyd couplers.........remote rams........front end weights......front and rear wheel weights......many different tire sizes. I too have never seen a series 3 or 4 without power steering or a cushion seat or a tachometer, but they were an option !!!!
wheatbreeder
thanks Dr Allis
power steering was an option on series 4 and mostly likely series 3.... probably by that time all tractors came with ps so the 170 came ps and the live hydraulics Morley
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7205 |
The difference in power steering between D17 and 170: D17 is a power assisted mechanical set up. 170 is fully hydrostatic - no mechanical linkage. We kinda got off topic about the Series III. If the tractor was really nice and original, I might offer $3500. |
RichinWis
Orange Level Joined: 11 Sep 2009 Location: Deforest Wis Points: 691 |
To answer your Series III power steering question, the answer is yes it was an option, because I have one with manual steering. Series III Diesel, with single front wheel. Thanks Rich
ac45
Orange Level Joined: 14 Sep 2009 Points: 395 |
Ive seen a series 4 with no ps, It was on a local farm auction 20 years ago, it was a cherry, we were going to buy it untill they went o sell it and started it and I walked up and grabbed the wheel , and nothing happend, we went over and looked at the engine, and no ps pump or anything, I couldn't beleive it , cause it was a late model one too.
Jim Lindemood
Orange Level Joined: 22 Sep 2009 Location: Dry Ridge, KY Points: 2569 |
Have to agree -- value around here for a decent looking / running d-17 III is around the $3500 mark -- can go up with additional implements, and if is real close to the buyers location.
Post Reply | |
