D17 series 1 power steering temperature?? |
Post Reply |
Morpar55
Bronze Level Joined: 01 Nov 2021 Location: Indiana Points: 116 |
Posted: 26 Oct 2022 at 6:32am |
I finally got a chance to use my tractor a bit yesterday, as it has been out getting hydraulic lines for the loader. I have the separate pump for the power steering on this tractor, and replaced the belt and fixed the leaks last fall which made the power steering work right again. Or so I thought. I had the tractor running for a couple of hours going through the new hydraulic system and when I went to put it back in the barn the power steering was gone! Any suggestions on why the power steering would quit after the tractor has been running a while?
1959 AC D17 Gas with some updates
Orange Level Access Joined: 12 Sep 2009 Points: 19585 |
Better re-check it this morning to see if it fixed itself. It takes pump flow (up to 8 GPM full throttle) and a pump capable of making 1600 PSI if required to, to make the system work. Then, the control valve has to be functioning correctly, sending oil to either end of the steering cylinder when commanded to. Also has to be 5 quarts of hydraulic oil in the sump under the radiator being able to get to the pump.
MACK
you replaced belt. What pump do you have for steering? Could have sheared key on pump pulley, sheared key in pump or lost oil. MACK
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8154 |
You have a 1959 D17 with belt drive power steering pump
AC720Man
Orange Level Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 4667 |
Was there different choices? My 59 has the power steering pump attached to the rear of the generator. One belt driving the generator which turns the power steering pump.
Edited by AC720Man - 26 Oct 2022 at 10:13pm |
All pre-series 3 diesels were driven thru the generator, which wasn't a great idea by the pretty high failure rates of the connection splines. All early gassers were driven thru the governor. Again, not the best of designs as the governor gear works loose ruining the gear and shaft. Somewhere in that series 2 ?? gas vintage they came up with the belt driven pump. The series 3 diesels also got a belt driven pump. But, any power steering "kit" from A-C would have been old or new style design by what year the kit was put together. So, you could have a 1957 model with the newer belt driven pump if it was added on later in life. Remember, power steering was always an OPTION, not standard equipment. Kind of like the 4-bolt WF on an old WD tractor.
MACK
Didn't know it was a diesel. Yes it could have sheared the coupler. MACK
Morpar55
Nope, it's a gasser. I checked the fluid level and belt tension (easy checks) and they are both fine. And when I first fire the tractor up the PS works as it should. Just once it has been running a while the power steering goes away and it's Armstrong steering! Which sucks since I have PS getting out of the barn but not putting it away which is when I REALLY need the assistance.
Post Reply | |
