D17 S1 change to alternator
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Topic: D17 S1 change to alternator
    Posted: 06 Jan 2016 at 1:30pm
Well I finally decided to change over from the generator to an alternator.  The generator hasn't worked in a few years and rebuilding it cost more that a reman Delco 10SI, so I took the plunge and picked one up.  Decided I might as well replace all the old stiff dried up plastic wire as well.  Looks like the easiest way to get at that whole area is pull the fuel tank off and wire in everything from above.  Ordered a 60amp ammeter and a new solenoid as the old one sticks when it is below zero, you have to tap it with a hammer to get the starter to disengage.  So I could never have the RH side sheet on.  At least in the winter.
I took off the rad and shell, set the new alternator in place and it looks like I can reuse the top slotted generator bracket.  I took the bottom generator brackets off, turned the rear one around and put it on the front and it looks like with a little rework I could make it work.  But decided to make a new bracket instead, looks like it is probably easier in the long run.  I'm one of the lucky few that is not burdened by the extra paraphernalia of power steering, so the area under and in front of the alternator is uncluttered.  I have seen some installations that have notched the hood to clear the alternator and I want to try to avoid that if possible.  I'm going to build in a bit of front to back adjustment so I can line up the alt pulley with the crank and water pump pulleys better.
The new alternator has a 2.5" pulley, 1" smaller than the old generator, so it should be whipping right along.  Not much belt wrap though, so that is a concern.
This will leave me with only one tractor left with positive ground.  I guess the future is here......
cheers,
Creek
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2016 at 10:22pm
Use the pulley from the old gen. Will fit on new alt.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 6:19am
Depending on the bracket you design, if you slot a rear mounting hole you can "pitch" the back of the Alternator in or out to dial it in on the other pulleys. This also takes any load off the main shaft bearing in the Alternator and sets the belt perfectly in line. HTH
Steve@B&B
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 7:11am
Be careful, the nose piece doesn't leave much room for one.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 7:33am
Well Creek, you've had almost a full day...where are the "After" pics?? LOLLOLLOL
I'm gonna try and do this to my Series I this coming summer also!  Alternator, new wires, add headlights and tail lights, amp meter and whatever else it needs.  NEW battery!  The one it came with is junk!
Edited by Ted J - 07 Jan 2016 at 7:35am
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 9:47am
The alternator often is fatter than the generator and so won't fit as close to the block and with the generator pulley will require a longer fan belt. If a one wire alternator, it has to be turned fast to start charging, so a smaller pulley can solve both problems. When I got an alternator for my 4020, I was able to get an extension to its frame that made it fit the generator bracket. I still had to slot the bracket mounting holes to move it enough for the pulley to line up with the other pulleys on the engine.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 10:55am
I opted for the 'newer' CS130 series alternator for my D-14s. Smaller but more power than the ancient 10SI series. Saved me having to hack the tin....FOUR times !!!!
It might ba an option for you ??
Jay
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 12:55pm
Jay
^^ This
The CS130 is a better alternator. It should be readily available in most junk yards on smaller 1990s GM cars.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 2:14pm
I've 'rescued' 4 of them from Cavaliers.Just be sure to get the connector at the same time ! At the parts store they're $20 !!!
Jay
Tcmtech View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 2:45pm
If you go the CS130 route there are one wire versions available too for around $100 or you can convert a used one to a one wire operation with a new one wire regulator for under $30.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 4:31pm
Still waiting for the bracket to be finished, I'll test fit it and if it doesn't work we can make another one. We have a giant Trumpf laser and computerized brake at work and unfortunately they are not very busy.
I slotted the mount holes vertically, not horizontally. I was thinking I might have to move it up a bit to clear the bottom motor mount and stay away from the throttle linkage.
I bought the 3 wire version, I want to put in an idiot light to back up the ammeter.
I checked the pulley on my generator, I was thinking maybe since they are both Delco they would have the same shaft diameter but sadly the 40 or 50 year difference in age seems to have eliminated that chance. Although there was a lot of crud on the generator, I'll have to clean it up and have another look.
I'll get more pics up when I fit the new bracket. Right now have a house full of in laws for the next few days and a cold front coming in. The high on Sunday is -4F so it will probably be 10F less inside my steel shop. Hard to get much done when you have to wear gloves.
cheers,
Creek
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 4:36pm
Jay
Generally there are two wires going to this connector. One for the (I)gnition and one for the (L)ight. Cut these two wires about a foot away from the alternator. You only need to use the wire that goes to the ignition unless you also want to use an idiot light. The CS130 (or 144 which is the same except for a cooling fan) uses internal sensing. You don't need to hook up a sense wire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2016 at 4:29pm
Well I got it mounted all right, the new bracket worked well. Here is the bracket in place.
Here is the alternator, I need a shorter belt then I can swing it over to clear the rad shell.
It lines up pretty good with the water pump
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2016 at 4:35pm
I'm going to use all 3 wires and put in an idiot light. Figured why not it can't hurt.
The wire from the alternator all the way to the ammeter makes me nervous - should I put a breaker or fuse in line? I found I had a push button reset 30 amp breaker, but I don't think that would be big enough.
I pulled the fuel tank and ripped out all the old wiring, going to start from scratch. New ammeter, oil pressure gage, rewire my new front and rear lights. Fix that valve cover leak too. Tie down all the wirew with rubber lined P clamps. Wires from the alternator to the valve cover are kind of hanging in space, so I'll take a bolt out of the back of the water pump and put a P clamp on there as well.
cheers,
Creek
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2016 at 6:54am
I'd move from the Ammeter to a Voltmeter for safety Creek with an Alternator up front. The three wire idea is a good one. Go that way with it. Looks like a nice mounting bracket ya made there and the belt alignment looks most excellent. Lookin' good man! Should be able to use the Gennie pulley on the Alt. Both should have the same .670 shaft. Keep us posted on how yer' comin'..
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2016 at 7:06am
Creek,
Be careful this is the way full restorations start!
You should be real happy with the conversion!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2016 at 9:38am
Steve - I've got my sights set on an ammeter, I have a 60 amp one I'm going to try. I was thinking maybe put a 50 amp fusible link in the main feed wire (I am using #6 wire, I had a bunch of it and figured why not) to protect the circuit. I have a can of liquid electrical tape I will apply to the ammeter connectors as well. Just in case a mouse or something has a holiday behind the dash. The wires going under the fuel tank have all been ripped out, I'm putting in new ones and putting them in plastic harness tubing. Too many moving parts - steering, throttle, hydraulics, under the fuel tank and I don't want to rub thru a wire.
Sugarmaker - I know, it's sad. I pulled the fuel tank, tore out all the wiring, noticed front spindles had some play so I ordered canvas strapping for under the fuel tank and new spindle bushings from OKTractor. And a new oil pressure gage. Now I am thinking as long as the ground is too soft to do anything and its not too cold in the shop I could drop the pan, fix that rear main oil leak, fix the valve cover leak, pull the front axle again and fix the steering box oil leak, shim the spline on the steering sector to take some play out of the steering, then might as well............but I still have to finish clearing a fence line, put up the fence and also go to my regular job that pays for all this fun.
cheers,
Creek
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2016 at 10:27am
Creek: Fusible links do more to protect the wiring when the alternator shorts out and the battery attempts to discharge through the alternator wiring. Ford trucks (maybe cars too - I'm less familiar with car wiring)use several #14 AWG wires tied in parallel. Four 6 inch pieces of #14 tied in parallel and insulated at the ends with shrink tubing should do the trick. Personally I'm more fond of an accurate voltmeter when using an alternator, but to each their own.
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2016 at 10:40am
I like a volt meter because you can see the battery voltage before you start the motor and know if you have a battery issue. Amp meters only tell me that the generator is working but not if the battery is holding a charge the next morning.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2016 at 10:46am
If your battery happens to have a shorted cell the ammeter is going to tell you that your generator is really doing its job well. As Dan said, the voltmeter will tell you the next morning that all is not well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2016 at 5:13pm
If yer' gonna use a fuse link, put it at the output stud of the Alternator to protect the Alt should a short take place. If it back feeds to the Alt, the fuse link will sever and protect the Alt. That's what I use on my wiring systems. If using 10 gauge out put wire, use 14 ga. fuse link. Rule of thumb, always go 2 gauges smaller off main circuit. 60/60 sweep Ammeter is the correct selection if you want to use an Ammeter. Watch the varmits!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2016 at 1:49pm
Well got the alternator mounted and everything put back together.
I also wired in an idiot light to go with the 60 amp ammeter.
Started it up and everything seems to work, but the red light comes on until nearly full throttle, then it goes out and the ammeter kicks over to charge. I hooked up the 3 wire Delco 10SI with the field and sensor wires going back to the dash, but must not be enough juice to get it going at idle. Battery voltage is 14 when charging. Not a big deal.
I also hooked up my timing light as it now works with the negative ground. Holy crikey that hole in the frame is small. I'll have find the F mark manually and paint it.
Just for grins I hooked up my old dwell tach as well. The tach part just pegs when I switch it to 0-1200 or 0-6000, I dunno whats up with that. Dwell says 40 deg, which I think means the points are set a bit tight - it's been like 30 years since I used a dwell meter so things are a bit cloudy.
My new oil pressure gage sadly reads even lower pressure than the old original one, which is really scary. I'm going to get a regular pressure gage and hook it into the line at the filter and see what it reads. Prob can take the one of my G or C and try it.
Must have crimped the capillary tube on the water temp gage when I put it in tubing with all the wiring, that is not working either, have to get a new one.
cheers,
Creek
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2016 at 1:58pm
It's not uncommon to have to wind up the alternator. Try putting a 470 ohm resistor across the idiot light.
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2016 at 2:08pm
Hey this is a timely post as I was going to ask some alternator questions because my father is thinking of doing this on his John Deere 50.
1.  Should one replace the ammeter?  in other words if the old ammeter only goes to 20 amp will it just peg out for a while if the alternator is putting out more amperage or will it cause an unsafe condition (such as heat and fire?)  I realize a voltmeter may be better, but am just asking.
2.  Where did you decide to hook up the sensor wire?  I see a lot of people just hook it to the output wire of the alternator but that kind of defeats the purpose.  Would probably work ok for old tractor use though.
3.  Where did you hook up the exciter wire?  It could probably just go to the + terminal of the coil if one didn't want hook up an idiot light on the dash.  What size diode does one use on the exciter wire?  Where does one buy the diode?  I understand it's needed otherwise the engine may not shut off when turning off the key.  Also I read there needs to be a resistor in the exciter wire.  Why is that?  I have also read that an idiot light serves as an adequate resistor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2016 at 3:00pm
1. I'm a believer in voltmeters. Just know how to read it and know that a 12 volt reading isn't good enough. You need about 14 volts. Calibrate this 14 volt reading against a good hand held voltmeter. If you insist on using an ammeter, go with a 60-0-60 version.
2. It doesn't matter so much if you have good heavy wire between your alternator and your battery. I'm a purist and I'd hook it to the battery. I had to change the sensing wire and connect it to the battery on equipment at my old job since the radio equipment was more picky about voltage. If you connect to the battery be sure and fuse the wire near the battery.
3. Connect the exciter wire to the "ign" point on the key/switch. Use a 1N4004 diode. They are a dime a dozen. You can uses a properly-sized idiot light too, and it should work. You don't need a resistor wire in the exciter circuit, but it is nice as a current limiter in case of a short. With a diode have the "band" side of the diode facing the alternator.
Edit: You can find a diode like that at most electronic hobby stores. Radio Shack use to carry them. I just don't know where you'd find a Radio Shack anymore.
Edited by DougS - 29 Apr 2016 at 3:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2016 at 6:46pm
The ammeter range needs to match the alternator capability so it has an adequate conductor inside. 60-0-60 is probably enough. The wire from the alternator to the ammeter and ammeter to the battery (usually connected at the starter solenoid or switch but can be at the battery post) should be increased to at least 8 gauge. I have a 10 gauge silicone insulated wire on my 4020. The silicone can handle the heat and with the voltage sample wire connected to the alternator post it limits charging current to about 35 amps according to the ammeter I added. Compared to the 20 amps of the original generator I'm happy with twice as fast charging. Its easier on the battery than hitting it with 60 amps charging but means I have to be a little more patient.
A voltmeter is definitely easier to wire, but depending on where its wired and how much resolution and precision it has it can give misleading information. The ammeter shows actual battery current while the volt meter shows voltage somewhere in the wiring between the alternator and the battery and battery loads. To truly show battery condition the voltmeter should be connected to the battery posts with separate connections from those used to load and charge the battery. But then it will run the battery down unless connected with a relay that disconnects it when the engine isn't running. Even in that case it needs better than .02 volts precision and display resolution. Most automotive shop volt meters don't have nearly that precision and resolution. When the regulator on the battery works right holding the charging voltage to 14.2 volts for a starting battery the battery current WILL taper to zero showing the battery is fully charged. That is an indirect indication the battery voltage has risen to 14.2 volts that could be seen on a precision voltmeter. I've tried voltmeter and ammeter lab quality in a car long ago and even with both the ammeter was way more informative.
The diode, resistor, or light in the excitation wire limits current fed back to the ignition system to prevent spark from that feed back current. Any of the three works. There are Radio Shack stores some places around the country. Look at http://www.radioshack.com for details. On line http://www.mouser.com and http://www.digikey.com have at least 100 different suitable diodes and probably a mere million in stock at decent prices, but shipping costs at least $5 though a dozen diodes could be mailed with one first class postage stamp. Neither has a minimum order price. Radio Shack sells on line these days too. Then there is epay. Any diode in the 1N4000 to 1N4007 family of 1 amp diodes or 1N5404 3 amp diode is adequate. The sturdier diode will stand up to vibration better because of sturdier leads. 50 volts is adequate PIV (Peak Inverse Voltage) and sellers in China will ship 100 diodes in that 1N4000 family for 99 cents or better. Might take a week or two to arrive and there's 99 left over.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2016 at 6:55am
I may have over killed the output wire, I had a piece of 6 gage laying around so used that. The ammeter is a 60 amp model. Have only run it an hour or so but usually starts out at 20-25 amps then slowly tapers down to near 0. I like to see what the alternator is actually doing, not just voltage. The sense wire is connected to the battery side of the solenoid. The exciter wire connects to the "acc" side of the key switch.
Cheers
Creek
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2016 at 11:34am
6 AWG is ideal, but costly and can be difficult to work with. Unless you are drawing a constant load from the alternator you can get by with something as small as #10. If the battery is very discharged rge smaller wire will self-limit the current anyway. As the battery charges the load from the alternator decreases, causing the charge voltage at the battery to rise.
