CA Engine Question
1955allisca View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955allisca Quote  Post ReplyReply Direct Link To This Post Topic: CA Engine Question
    Posted: 01 Sep 2014 at 4:58pm
Has anyone ever took the piston and sleeves out and just put big pistons in a CA, is it possible? And if so what size pistons does it take?
dgerth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dgerth Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2014 at 10:14pm
For starters, It's a wet sleeve motor so your limited quite a bit there and I am not aware of an over-bore kit for a 125 motor. You might want to start with a 149 motor or maybe a 160 if you can find one. I am not sure what you mean by big pistons either, I guess refer to the previous mentioned limitations.
dg
