B exhaust |
Post Reply |
DaveWisc.
Orange Level Joined: 11 Oct 2009 Location: Wisc. Points: 963 |
Posted: 30 Oct 2022 at 7:27pm |
Can a exhaust be welded broke a front piece?
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78002 |
you can try... Cast iron does not weld good to start with... when its 70 years old you have a lot of carbon and not much iron left.... I have repair the front or rear EARS on a couple with some luck.... Not much luck with cracks / rust out in the center port areas.
clean it real good... then clean it again...grind a bevel on both parts.. clamp them together in alignment.. heat with a propane torch to 250 degrees in the area an inch around the weld.......... i use 7018 DC stick on everything.. One short pass, then chip with hammer to get the flux off and releave stress .... after 1 minute, do another short pass or buildup... dont weave the rod, just do short beads. Edited by steve(ill) - 30 Oct 2022 at 8:40pm |
DaveWisc.
Maybe easier to buy used one
yes.. if you have the time and expertise its worth a try.. If your going to pay someone to weld it, FORGET IT..
1939Dodge
Orange Level Joined: 18 Jan 2014 Location: Pa. Points: 553 |
7018 will wreck the parts. Preheat, use a nickel rod. Or BETTER, braze it with a brass rod and torch. It’s much easier on the iron parts and will prevent carbon from
Migrating into the grain boundaries Edited by 1939Dodge - 31 Oct 2022 at 7:48am |
IBWD MIke
Orange Level Joined: 08 Apr 2012 Location: Newton Ia. Points: 3474 |
As Steve says, cast iron is tricky to weld under the best circumstances. After 70 years of heat-cycling, probably near impossible. There are new ones out there, that's the way I've gone. Both of my CA's where new manifolds.
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7205 |
Better off getting a good used one. There should be millions of them out there.
HoughMade
Orange Level Joined: 22 Sep 2017 Location: Valparaiso, IN Points: 691 |
I have a new one from Steiner. High quality piece.
1951 B
Post Reply | |
