Unofficial Allis Homepage
ALLIS-CHALMERS G PEDAL TRACTOR - $200 (Muscatine)
dannyraddatz View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Topic: ALLIS-CHALMERS G PEDAL TRACTOR - $200 (Muscatine)
    Posted: 15 Sep 2013 at 4:29am
Danny Raddatz
1954 WD45, AC 5 ton running gear
Fred in Pa View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2013 at 6:00am
They did OK with the front part ,rear part is no where close.
AJ View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2013 at 8:33am
It don't seem to have the detail of many other pedal tractor I usually see in the engine area.
Edited by AJ - 15 Sep 2013 at 6:09pm
Can't fix stupid
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2013 at 1:00pm
There's a pedal tractor in the ad ? I was too busy looking at the calendar. Oh yeah if you guys can do better for 200.00 I would like to see it
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2013 at 1:14pm
When I get to it I will post a picture !!
FloydKS View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2013 at 1:17pm
I am kinda with Pat on this one...maybe alittle lazy on the back side but it is only a pedal tractor :) first thing you see when it is commin atcha is the front :)
AJ View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2013 at 6:10pm
Changed what I said since it was taken in a negative manner...
Can't fix stupid
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2013 at 6:32pm
AJ I did not think you gave a negative response, just thought for 200.00 it was not bad. Yes the rear end does not come close to a real one and would have hoped they would have made one much more like the original.
Fred ,,, I am still waiting
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2013 at 6:50pm
I am busy with other project's,it will be awhile !!!
norm[ind] View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2013 at 6:57pm
turners in alabama  made good looking unit have seen them but have no pics
 not for $200.00 either
JoeM(GA) View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2013 at 7:41pm
this is the type the Turners built -
Allis Express North Georgia
41 WC,48 UC Cane,4-G's,
Ford 345C TLB
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2013 at 8:56pm
I'm gonna have to see if I can get a 'Snap-On' calendar!  There is a tractor somewhere in there?
19?? WC / 1941 C / 1956 WD45 / 1957 WD45 / 1958 D-17
oldways View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2013 at 10:42pm
Man That Turner Pedal Tractor Is Slick !
1 Corinthians 1:18 1969-190xt-III 1948-G 1937-WC unstyled. 1950-B
