Allis WD NFE (Was Dads) |
Post Reply | Page <1 3456> |
LSilseth
Bronze Level Joined: 29 Dec 2014 Location: NYA, MN Points: 196 |
How do I get a pic from email to here?
Luke
MN FARM BOY
Luke www.silsethfamilyfarm.com |
LSilseth
L,
Take and post some pictures of your tractor project please! Regards, Chris [/QUOTE] Will do. It might be little bit(:
MN FARM BOY
Sugarmaker
Orange Level Joined: 12 Jul 2013 Location: Albion PA Points: 8168 |
L, Take and post some pictures of your tractor project please! Regards, Chris |
Sugarmaker
J.W. The rim was cut in half to replace one half that was rusted very bad. I did not widen the rim. Here is one area to look for. Check the rail construction to the rim, are they welded with a bead on the rail sides or resistance welded through the rim? If welded on the outside (bead of weld) then you can carefully cut into the weld and separate them. If the rim was built with spot welding process it is going to just about ruin that side of the rim to save the rails or the donor rim replacement. (I have not done a spot welded (resistance welded) rim repair. You might look at D17 rims I think they are made wider, to handle your tires or combine rims might be the ticket too? Regards, Chris |
j.w.freck
Orange Level Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
sugarmaker.....I noticed you had one of your rear rims split.did you turn it to a 16.9 rim or just do a repair?i have a 45 diesel puller I want to add a section to widen the rim for a 16.9 tire.how much trouble was it to break the slide bars loose? thx.....
Sugarmaker
Folks,
I made a run at these rear wheels for Dad's WD today. Some shots as to how I assemble them. No one ever taught me, so this is my method. Seems to work. I tape the rail contact item into the bracket. The tape will be removed after the brackets are in place. Wheel stops are ready. Note to self: check the holes and make sure they are not full of rust in the rails. Add the first bracket to the wheel finger tight. Make sure the ecentric is in the unlocked position ( turned counter clockwise). Stand the rim/tire about vertical with the rail holes at the bottom. Install the rail stops and tighten. I then set the wheel and first bracket in between these stops and reach through the center of the rim to install the bolts in the next bracket. (sorry my hands were full holding the wheel prior to the second bracket being installed). After all the brackets are installed, remove the tape holding the contact metal parts in place. All brackets in position with bolts finger tight. I tighten all four eccentrics about half way. then tighted the 8 nuts on the bracket bolts to the wheel. Then tighten the eccentrics to full lock. I wiped down the tires with Bleach White product just to get the dust off. Touched up some paint issues and set them aside. Back on the tractor. I did find it today, and was able to raise it and attach my rear support which allows me to safely clean the castings and start inspections. Also allows me to install the new final drive bearing races, and the wheels will be able to be installed at a later date. Regards, Chris Edited by Sugarmaker - 13 Jan 2015 at 8:16pm |
Sugarmaker
Not a problem! take your time. I have had way to much practice on this forum and several others too. If I spent more time doing things rather than talking about them I would have most of my stuff done:) Both these WD's needed rear rim work and bearings and seals. Regards, Chris Edited by Sugarmaker - 13 Jan 2015 at 7:46pm |
LSilseth
Cool pics. Ours is down to the cast iron too, but we don't have the back wheels off.
PS: Sorry for the blank post I am still learning this forum.
MN FARM BOY
LSilseth
MN FARM BOY
LSilseth
Oh ok I see(: I had not seen that one either.
MN FARM BOY
Sugarmaker
Ted, I did not ask NAPA if they had the clips. I had found some fairly good used ones. The last clips I got were from Sandy Lake and they were a little pricey I thought. The NAPA store is so convenient that I cant hardly afford to drive anywhere else. But I do like buying hardware by the pound at Tractor Supply too. Regards, Chris |
Sugarmaker
LSileth, Sorry brain was in neutral, I meant NFE (Narrow Front End). Regards, Chris |
Ted J
Orange Level Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18727 |
Chris, did you get the 'C' clips at NAPA? I need some new ones for my WD45.
I get bolts and nuts at Farm & Fleet. They sell them by the pound there. A LOT cheaper! Grade 2, 5 and 8. |
LSilseth
What does (NEF) mean? I have never heard that before.
I am working on a WD-45 right now(: it is our first restoration project.
MN FARM BOY
Sugarmaker
Folks,
Ok, I didn't like the looks of those old crusty 5/8 nuts either, so stopped at my favorite NAPA and got 16 new ones this morning. Found the snap "c" clips for the eccentric pins and have those assembled and ready. Will try to get some shots as the wheels come together. Regards, Chris |
Sugarmaker
Folks,
Just a brief update as we move slowly forward; I think there is a WD tractor in here somewhere? I have never been known for keeping a immaculate shop and it sure shows here After a good wire brushing, some fresh Persian Orange has been applied on the 8 brackets for the wheels to mount to the rims. These will be taken apart and never seize will be applied to the moving pins before assembly. Rim stops for the rails. These will get some never seize on the threads and shank also. Cam contact for the eccentric to rail Dusty tires, 13.9-28's and rims ready for the wheels. Outside of the stove bolt type rim bolts (Persian Orange) using the Krylon 1820 rattle cans at this point for small items. A little pricy but very convenient. Going to use the old hardware nuts, some are a quite pitted as you can see. Just have to draw the line somewhere from a cost standpoint I think. I can't do this like Steve @B&B Inside head of rim bolts are cream color (Rustoleum Antique White) to match the rim color. It was a year ago when I took these rear tires and rusty rims off Dad's WD. Twas a project getting them unmounted, rims sandblasted, cutting the rims apart and welding in repairs and painting, new tubes installed and tires remounted. Glad I did not have to get new rubber also, that was expensive enough:) I did not do the unmounted and remount work. I had local tire shop do that. Was easier for me and they never scratched the paint. I do know that when I got these tire assemblies done and assembled on Jacks WD tractor, it was a major milestone in the restoration process! They are just big bulky, needed major repairs and have a lot of components to get them back together. Really glad I brought these along through at the same time I did the other two! By the way these are not filled tires. If I was going to fill them it would be the new beet juice product after they are in place on the tractor. With some luck I may be able to get these rear wheel/rim assemblies together and moved outside under a tarp soon. Providing some much needed work space around the tractor for some next moves. Hope things are good in tractor land! Thanks for following my ramlbin'. Regards, Chris Edited by Sugarmaker - 13 Jan 2015 at 11:58am |
Ted J
You're welcome Chris! Sometimes in the dead of winter, we all need a little shove as we tend to get a little lazy. Especially at our age. or is that a ?
I hate winter only because I can't get things done that I want to! Makes the old lady.....OOPS, the little lady, happy though. I installed a new garbage disposal and a new bathroom faucet and terlet (Archie Bunker) for her. Now I wanna get going on my tractors! and the pole barn! Have a great new year and congrats! I can't wait to see the finished pic! |
Sugarmaker
Folks,
Ted got me moving a little today. I wire brushed and primed the 8 brackets from the wheel to the rim. Also the eccentric pins and the little blocks that ride on the eccentrics. When those get some color I should be able to assemble the wheels and rims and move those out of the garage for some much needed room around the WD. Pulled out most of the sheet metal and blew the dust off those. Also cleaned up a little around the WD. I can almost see it again. Thanks again Ted J. Regards, Chris Edited by Sugarmaker - 11 Jan 2015 at 3:42pm |
Sugarmaker
Ok if thats the picture, then yep mother nature rusted out that fender to the point it was just the support structure remaining.:) Regards, Chris |
Sugarmaker
Shameless, I think I am good right now. Thanks! Regards, Chris |
SHAMELESS
Orange Level Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
I saw a new manifold for sale on Omaha ne craigs list if yer lookin
JayIN
Orange Level Joined: 18 Dec 2009 Location: SE/IN Points: 1982 |
I think he means the one that is rusted clear off.
Sugarmaker
Tim, Confused about your statement could you clarify? Which picture? I have a lot going on in the pictures. Any of the pieces I cut out were from a junk donor fender that was in the scrap pile. There are some WC fenders, paint not as shiny, in the pictures also, that set were restored and mounted on the WD WFE I just completed. Hope that helps? If not keep asking, I love to chat:) If it is this picture?, the notch at the front bottom is factory stamping. I saw a pair of these on a IB tractor last year. When I bought them at a local swap meet, I did not realize that they had the wider front leading edge compared to a WC or WD fender. Maybe someone on here has the reason for the two style fenders? Bill Long? If this is not what your referring too let us know! Regards, Chris Edited by Sugarmaker - 11 Jan 2015 at 7:44am |
Sugarmaker
Bill, Man that would be nice if you could find that WC flat top. ( I need to brush up on my WC's as I wouldn't know a flat top if it fell on me:)) Thanks! I wasn't to interested in this family tractor about 6 years ago. It just needed so much work. My uncle gave me a price on it and I did not bite, thought it was a little steep. When I finally did by it from his wife, I paid almost what he was asking anyway and now am very pleased that it is setting in the garage. I was offered both of the WD45s that my Dad had also. that was 15 years ago. It was part of a family feud at that time and I really did not have the time or funds or need for them. Now I realize its not need its "want" :) Wonder if they still exist? Hummm???:) Regards, Chris Edited by Sugarmaker - 13 Jan 2015 at 11:51am |
Sugarmaker
JW, In 56 I was 4 years old:) So sorry to hear about your father. Glad you have that tractor! I am looking forward to having this family WD restored someday. I remember hanging out at the local Allis dealer about 2 miles from us. My dad may have bought this WD from there too?? We had a 1956 WD45 WFE with power steering on the farm and it was a good running tractor. Regards, Chris |
tim 52160
Orange Level Joined: 10 May 2013 Location: indpls in Points: 314 |
Just out of curiousity why did they cut that one fender down like that? didnt make any sense to me. Was there a purpose to it?
Bill Long
Orange Level Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Thanks for saving another Allis Chalmers WD tractor. Especially your father's. I know these family tractors have a very special meaning.
I always wanted the first Flat Top WC my father sold. I did know where it was located but - much to my regret - did not follow up on it. I still kick myself to this day. Good Luck! Bill Long |
j.w.freck
sugar maker,you will cherish and appreciate that tractor more than any you own.i have the wd-45 I drove home from the allis dealer in 1956 when I was a junior in high school.got it when dad got killed on the farm about 9 years ago.never left the farms since brought new.....
Sugarmaker
Since the fenders were gone I picked these up last summer. They needed a lot of work. I think they may be from a IB tractor they have a wider front lip than other std fenders. They are not so different that they will look strange. So for $6.50 each and a lot of work these are the ones that will go on this WD.
lots of dings, dents, rust out and rips in the edges. Some MIG welding of patches on the fenders, Most of the edge patches came from Dads left donor fender. I even cut out the holes for the taillight and moved them to the new fender. These have been smoothed out more and are in primer. Also picked up this rad shell that may have been from a WC?? Was rusty and bent in the upper front, but better than the shell on Dads tractor. Still has the original screen. This radiator shell is in primer ready for final filling and sanding work too. Hood: Built the buck to hold it while finishing. Added the 1/2 x 1/2 angle iron support under the hood for strength. filling and sanding Hood is fairly flat and straight and in primer. Waiting for the weather to get warm to finish these. Rim repair Centers are cleaned and painted. Need to clean up the eccentrics and brackets, Regards, Chris Edited by Sugarmaker - 10 Jan 2015 at 9:20pm |
Sugarmaker
Mark, Thats a cool serial number on your WD and easy to remember. Do you have a wide, narrow or single front end? Still learning a lot about these WD's.They are starting to grow on me! I have to round up the serial numbers on these tractors. Hummm, maybe I did post them on here some where? There is a listing somewhere right? Maybe on the home page? I really did try to work on some of the same parts this summer and fall when I was doing the other WD. So I do have a little bit of a jump on things. This time last year the rear rims were not even started. They are complete now with tires re-mounted and ready for the wheels to be installed. Trying to decide if the engine should come out for a good look at all the seals and to see how it looks? That would be the right thing to do, not that I always do the right thing in life:) Then I could do the pan gasket work and the front cover gasket as Don(MO) suggests. Would be a great reason for me to get a HF engine stand. and get my engine hoist base back from my grandson. Yea that's a plan! Regards, Chris |
