Allis "Forty Five" injection pump information need |
Post Reply |
Ian Beale
Orange Level Joined: 03 Oct 2011 Location: New South Wales Points: 934 |
Posted: 05 Aug 2012 at 6:46am |
The Saga of the Injection Pump for an Allis “Forty Five” Grader We've been resurecting this grader to ranch useable, with considerable help from an Allis savy neighbour.. Engine is the ADS 516 with belt driven supercharger. We started with an engine that had dropped a big end bearing and been left open. Found an unused rebuilt short motor from a liquidation sale,including what looked like a rebuilt injection pump (new looking lock wires etc). Got 2 good cylinder heads and put it together. Rounded up our collection of 15 injectors and borrowed a neighbour's tester. Came home with 8 useable. Plucked up courage, put 6 in and it started on the engine stand. Next morning most of the remaining fuel in our temporary tank was in the sump. Following a lot of asking before doing we found the bottom o-ring for the hydraulic head on the pump was missing the 3-legged clip for the bottom of the head was squashed the distributor timing was out by one tooth. the govenor linkage was sticking – took our diesel apprentice son most of a day to find the burr on the spill valve control shaft that was doing this As of now it needs just a sniff of aerostart to get going – cold or hot. Runs fine once going, with a clean exhaust. Which would be fine for our use, but it should be better I'm told. Now some more detail on what and maybe where to. The pump on the original engine was PSB6A 100EH 4080F4, rev range 600 - 1600rpm #4347865 (which is according to the parts book) The head is HD 4067AR (rebuilt) Timing is 28 degrees The injectors for this pump were wound well down and it will not work with injectors set at recommended pressure. Plus it has an extra bit of wire to hold some of the govenor linkage. The pump we have on it is PSB6A 90EH 4083E1 rev range to 1800rpm. #4347866 Head HD 4??8AR (the plate is damaged). (Also rebuilt). I have parts and service manuals for HD11 dozers which detail that Allis was chopping and changing plunger size (10 or 9mm) and timing (10mm 28 degrees, 9mm 32 degrees). This part number is listed in the HD11 parts book for engines before 10-4855. and was timed at 32 degrees. It also seems that the one tooth out on the distributor might have been advancing the injection timing – but it also looks like the plunger was hydraulic locking until the distributor slot opened. Which doesn't sound healthy for the head IMO, but might have given a jolt to the injection.. So do I Leave it as it is? Think about 32 degrees (But what about the supercharging, as I've been told that 28 degrees is common with turbos) Think about finding a good 10mm head and fit that? Suggestions and information will be appreciated. |
TramwayGuy
Orange Level Access Joined: 19 Jan 2010 Location: Northern NY Points: 11260 |
If you don't already have this information, you should:
With this information, I was able to locate a NOS hydraulic head for my Oliver 88, a different part number than original, but the latest upgrade. |
Ian Beale
Tramwayguy,
Thanks.
I'd found the first one. The second one seems to list only one head of the number I probably need, but I will have to study more.
Also there seems to be an Allis manual on PSB pumps that I've seen on a local machinery type publishers list - doesn't quote a reference number.
Ian Beale
I've heard that there is a later AMBAC? pump that was used on IH wheel tractors which will adapt to replace the PSB6 type pump on this form of Allis. I'm guessing it is one where the injector pipes come out of the head at a slight angle. Any Info appreciated.
CAL(KS)
Orange Level Joined: 18 Sep 2009 Location: Chapman, KS Points: 3746 |
i thought i had a contact for a guy in missouri, who specialized in BUDA/LANOVA motors, ill have to see what i can dig up.
Ok, here is a name and number I was passed for BUDA/Lanova engine. This is all i have, and i have not spoken with him. maby he can help, if i remember correctly Ian, you are from Australia? might be worth a LOOOONG distance call. good luck
Jim Cousins @ 318-222-3348 Edited by CAL(KS) - 10 Aug 2012 at 10:53pm |
Post Reply | |
