Allis Chalmers 912 lawnmower |
Post Reply |
hunter321
Silver Level Joined: 11 Jan 2021 Location: 52320 Points: 449 |
Posted: 13 May 2023 at 7:29pm |
I am fixing a mower for my uncle and need to know everything that could be wrong with it
He said engine problems |
AC720Man
Orange Level Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 4641 |
Until you start diagnosing what is wrong not sure we can be of help. A lot of things can cause engine issues, once you get it make sure it has fire to the spark plug first. And go from there.
Gary
Orange Level Access Joined: 13 Sep 2009 Location: Peterborough,On Points: 5173 |
Start with the basics. A Gas Engine needs 3 things to run: Fuel - Air - Spark Like 720 says, make sure it has spark. Then move on. G https://www.tractordata.com/lawn-tractors/000/1/5/154-allis-chalmers-912.html ..................................................................... This gentleman Zippo Varga is very knowledgeable about Allis / Simplicity Tractors https://www.youtube.com/results?search_query=allis+912+engine Edited by Gary - 14 May 2023 at 7:54am |
hunter321
I need to pull the engine
How do I do that |
Gary
For the past year you have been on the Forum requesting help with a dismantled Engine in an Allis D-12. Now your starting another project regarding a Allis Model 912 Engine. and you ask the simplest of questions ! How do I remove the engine ? How the hill do you think you would remove the Engine ? Unbolt the appropriate bolt, nuts, brackets, wiring, cables etc that are attaching the Engine to the Tractor and then lift it out. What am I missing here ? G |
Leadoff
Silver Level Joined: 14 Oct 2016 Location: Calgary Points: 266 |
hunter321
There are many excellent YouTube videos on how to do whatever project on repairing/tuning Garden Tractors. I have found Zippo Varga to be one of the best, and he seems to specialize in Allis Chalmers and Simplicity(identical to Allis Chalmers - same ownership/manufacturer). He explains lots of details, and speaks at a level most owners can understand Here is a link to one of his recent vids. The second link is his YouTube video library Good luck PS he has several videos showing in great detail how to remove trhe engine
1963 D17D Series III. 1965 D15 Series II. 1965 D17 Series IV. 1975 185. 1978 716H. 1979 716H. 1965 780 Harvester/1R&DC. 1957 Model 73 SC 4 Furrow Plow
hunter321
I got the engine pulled and the piston disconnected at the bottom but it won't pound out.
Also the flywheel seems to be seized. So far it needs gaskets possibly piston rings |
hunter321
I looked up the mower on tractor data and it said it has a Kohler k301s but I can only find the k301
Gary
I believe the S means it has a Factory Starter. G |
hunter321
Ok
So I can find gaskets for the 301 |
hunter321
Ive looked all over for the correct way to wire the coil and can't find it
How do I wire it |
hunter321
I have power to the points and the positive and negative points on the coil but no spark
Any help Is greatly appreciated |
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3296 |
keyed battery power to the coil from the coil to points points must open and close and the contacts must be smooth and clean and gapped and condensor needs to be good . most all of the k 301 stuff fits
hunter321
I am looking for a cheap head for the k301 any suggestions on where to get one
hunter321
The mower suddenly lost spark
hunter321
Does anyone have a wiring diagram for the mower
I am not Shure what I am looking for |
Post Reply | |
