allis chalmers 616 front tire interference issue |
Post Reply |
coggonobrien
Orange Level Access Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1806 |
Posted: 25 Apr 2015 at 12:01pm |
ac fleet
Orange Level Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2210 |
Are your tires the proper factory called for sized ???---also some brands of tires have an extra layer of rubber along the side wall and this makes for a go--no go fit on some applications!
2) do you have the right rims on your unit? 3)You could cut an re-position the rims to gain the clearance, (a LOT of work) but a possible cure. 4) grind some off the tie rods.---do you have the right sized tie rods ?? If your rims bolt to hubs ,--add spacers behind rims. thanks; ac fleet |
Dgrader
Orange Level Joined: 17 Jan 2015 Location: Newton,IL Points: 1037 |
Looks like ya need some spacers on the spindle to shim em out.
Ya cain't fix stupid.
coggonobrien
Tirs/wheels are right. I will burn some spacers.
coggonobrien
Anybody know the bolt pattern
Tracy Martin TN
Orange Level Access Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10557 |
Have you had your deck on it? Might want to see how close it runs to it. Has your had the factory service update done to front axle tube? Are those factory rims, are they centered or off set? Tracy
AcFordHawk
Silver Level Joined: 12 Sep 2009 Location: Boone, IA Points: 215 |
Bolt pattern is 4.5" X 5.
IB (restoring), MF GC1705, MF 2705E
Brad in WA
Bronze Level Access Joined: 29 Sep 2009 Location: Lynden,WA Points: 191 |
Like Tracy said, might want to check clearance if your putting deck on it. My 620 axle was slightly bent and tire would rub.
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3291 |
the originalgood years on mine are realy close about 1/8 to 3/16 clearance tracy what are the service updates
Tracy Martin TN
The factory service bulletins showed two things to do. One was the axle tube had a block with a tapped hole welded to the front axle frame. This kept axle from wobbling and letting tires rub the mower deck. The other was to add a bead of weld to the spindle housing to keep the front tires from rubbing frame in a hard steering turn. HTH Tracy
BrianC
Orange Level Joined: 16 Jun 2011 Location: New York Points: 1613 |
I have a 620, tires are 20x8.0-10 Goodyear, look similar in pattern. I don't know if the wheels are stock or not (offset issue). I see my sidewall clearing 1/2" on the left, 3/4" on the right. One thing I noticed is I have much less thread showing out of the tie rod. Can the arms be re-indexed? I thought it was just a single woodruff key, not a spline.
My right tire can just barely rub the deck. Another thing, mine turns sharper one direction vs. the other. |
Tracy Martin TN
It has a single woodruff key in spindle. There are 2 types of spindles. One is heavier that the other. Most noticeably on the steering arm itself. Your toe in and out could possibly be wrong. Check the steering arm out of the box. Count the total turns it will make from one extreme to the other, center it, and then see where your front tires are. They should center up also. The toe in is controlled by the front tie rod, it should be close to the same thread showing on each end. I would try to have the toe in about 1/8 to 3/16 of an inch. HTH Tracy
Post Reply | |
