Allis 8050 engine build |
Post Reply | Page <12345> |
Peterson
Orange Level Joined: 05 Mar 2011 Location: Westboro, Wi Points: 862 |
Sounds like improper installation to me. Like someone not oiling the o-ring on the top of the filter before you put it on, and not being able to tighten the filter on all the way on. If you really think that Baldwin, Fleetguard, Cat, WIX, CARQUEST, NAPA filers are bad. Better go tell the thousands of farmers, truckers, loggers that they better put on OEM filters otherwise its going to wreck the engine!
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Lonn
Orange Level Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29773 |
Aftermarkets can be fine if they are the right type and micron. Many come out of the same building but if the microns are wrong you can mess up your engine. Fram used to be absolutely no good no matter if the microns were right or wrong but it's been years since I cut one up to see it's guts. 20 years ago they were glued together inside and every one we cut apart in mechanics school had come apart at the seam and they had far fewer pleats than an OEM filter, so no, not all filters are built the same. I don't care what claims ares made. I'd cut it apart first to prove that they are the equivalent. Glued seamed vs metal crimped seams, twice as many pleats means a whole lot more filter area. It all ads up sometimes to you get what you pay for.
Wink I am a Russian Bot |
Carl(NWWI)
Orange Level Joined: 13 Sep 2009 Location: NW WI Points: 948 |
All comes down to the micron rating. If the micron rating isn't the same you can have problems. Seen time and time again. Its like trying to breathe through a or sraw or a 1" hose. One is a lot easier then the other.
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4786 |
filters are built by other companies to the oem company's specs. Not all cross referenced filters are exactly the same.
Peterson
Hey Dr.Allis the luberfiner filter LFP3191 that the agco filter crosses to, They list that to cross over to this 1r-0739 also.
Orange Level Access Joined: 12 Sep 2009 Points: 19596 |
How lucky for you then. By sheer dumb luck the numbers supposedly interchange. It's pretty clear that you did no prior research on this matter except finding something that fit the threaded base.
Peterson
Actually no, I did cross fleetguard numbers. Then found a Cat filter that fit. So no dumb luck here.
CrestonM
Orange Level Joined: 08 Sep 2014 Location: Oklahoma Points: 8357 |
Dadgum! That looks great! I can only imagine how complicated those engines are! I'll admit I thought engine rebuilding was easy after I completed my Ford 8N, but now that I think about it, it's a 4 cylinder flat head and it couldn't hold a candle to what you have done! Great job and keep the pics coming! And maybe post a video of the first start-up!
Peterson
Thanks man!!!
Here's some more progress as of today. Had to get a different reman water pump. The other one had the hub pushed on to far and the pulley would rub. So got a different one and it fits good. Here's the return line that's tee'd together. Pump fittings and throttle. Here's from underneath, see the throttle cable bracket I made. Top view. And the injector return line by the injectors. And no its not touching the valve cover. |
Peterson
Also I've had it running to set up the throttle. I pre-oiled the turbo and cranked it over until I had oil pressure then I fired it up. Didn't take many revolutions until its started. I will get a video when I get it ready to pull out of the shop.
Peterson
Got alittle more done today. Waiting on the front pivot for the axle yet. Hopefully be able to pull it out of the shop by the weekend.
JPG AUSTRALIA
Orange Level Joined: 13 Sep 2009 Points: 736 |
Lookin good! Great job
DonDittmar
Orange Level Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2476 |
CAT filters are made by Donaldson, but they are made to CAT specs. The dDonaldson branded filter is NOT the same as the CAT filter. CAT filters are made to much tighter specs.
The 1r0739 is the filter for the medium duty line.....3116 and 3126 use this filter. The high efficiency version is 1r1808 and that is made for the ACERT medium duty like the C7 |
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start |
Peterson
Our D6D Cat dozer with the 3306 takes the 1r0739 also. 1r1808 is the almost the same filter, just a finer micron rating. The 0739 is the standard efficiency filter, 1808 is the Advanced efficiency, therealso is a ultra high efficiency filter also but I dont have that part number.
Edited by peterson - 21 Apr 2015 at 7:13pm |
Peterson
Got more done today. Front axle installed, turbo intake and exhaust made up to fit factory locations, hood and grill on. Couple little things to go an she will be ready for field work!!
The welds look better in person than in the pictures. lol Edited by peterson - 23 Apr 2015 at 7:11pm |
Peterson
Also I will be stuffing that radiator surround with foam! Incase ya'll were wondering.
AC7060IL
Orange Level Joined: 19 Aug 2012 Location: central IL Points: 3212 |
Peterson, I've enjoyed reading about your progress on the 8050. Is it back in the field yet?
Peterson
Yes I have had it in the field for a couple days now. Got it done yesterday. Almost forgot to show ya guys this though. If you have ever changed the fuel water separator filter, you'll know why this is awesome! lol
Then a few pics of the finished tractor. Then a pic of her in her work clothes. Can see the dual on her that we got this spring. Special bands on the duals to work on the step rims. Edited by peterson - 27 Apr 2015 at 6:35am |
Peterson
Under a good load, she will pump a good 25 pounds of boost. Also turns the air filter light on. But it did that before with the stock turbo. The air filter is clean also. I've been looking for a 8070 air cleaner to put on it. Hopefully I can find one reasonably priced. But all in all I really like the pump and turbo upgrade. Seems so much more responsive than before. I want to get the rings seated and then take it to the local dealer for a dyno test.
Lynn Marshall
Orange Level Access Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2156 |
Has the front axle been moved forward on this rig? Also, what have you changed on the weight rack to move it forward? Looks good and I bet the performance is impressive.
Peterson
Yes I have moved the axle forward on all three of our 8000's. Just moved the rear holes in the axle mount to where the front were, and then drilled the four new holes. I made a bracket that bolts on where the original weight bracket did and moved it about a foot if I remember right. 1" steel front, back and sides with 2 pieces of 3/4" placed on thirds inside the bracket. Pretty easy to make. Plus it seconds as a bumper. Not that use it as one anyway. Just protection for the grill. I can snap a couple pics later today when I go disc. This tractor also has 16.9r28 on the front and 20.8r42's on the rear.
Kevin in WA
Orange Level Access Joined: 08 Feb 2010 Location: Lynden, WA Points: 607 |
I don't think your head gasket is going to like 25 lbs of boost for very long if you are pulling it steady that way, also what do you have for a radiator?
Peterson
No im not keeping it at 25 pounds all the time Anyway. It has a newer radiator in it. 5 row 3/4" core with 8 fins per inch. Same as our 8070's. Makes alot of difference.
LSilseth
Bronze Level Joined: 29 Dec 2014 Location: NYA, MN Points: 196 |
All We use is CARQUEST.
MN FARM BOY
Luke www.silsethfamilyfarm.com |
Peterson
Here's some pics of the front weight bracket spacer.
Then we cut the rear pivot for the 2wd axle. I just cut the front one off when I put the engine in. Much easier to slide the front axle under. |
acd21man
Orange Level Joined: 07 Jan 2010 Location: tn Points: 831 |
peterson. have you got a 185 140hp?? just readin the stuff below the pictures... what have u done to it?
Peterson
Yeah but that was the last time it was dynoed, with the stock pump turned up with 7080 tips and a hx35. It has a Dm4629 on it now turned up with 7080 tips and a holset he351. Few more horsepower than before. :-)
acd21man
wow i like it lol any probs.. im sure there could be. some guys down the road have a 180 with a turbo on it runs pretty good. so is that a jd pump on it? iv read some much on this post thought i seen somthing bout a jd pump on somthing i was readin got a d21 needs some help wana do something like this
Edited by acd21man - 28 Apr 2015 at 8:53pm |
Peterson
No the pump on the 185 is off a uni power unit 426 engine. Got it cheap so I used it. The Deere A-pump is on our 220. Works great but I wish it didn't have the timing retard notches in the plungers in the pump. And no, haven't had any problems with the 185. It has a 649 engine in it from the factory, so its the latest and greatest 301.
Edited by peterson - 28 Apr 2015 at 9:00pm |
acd21man
ok so the jd pump is on the 220? ok what did u have to do to swap. got a junk 466 outa a 4440 with pump and all on it. how easy is it to make run?
