917H |
Post Reply |
acd17toy
Orange Level Access Joined: 11 Sep 2009 Location: USA Points: 688 |
Posted: 08 Jan 2014 at 6:03pm |
what would a non running one be worth, seller says needs battery, and carburator rebuilt. comes with mower deck[needs new blades], snow thrower with loose chain drive sprocket. decent paint and tires.
ctbowles58
Orange Level Joined: 17 Jun 2011 Location: Clarksville, MO Points: 2249 |
WELL YOUR ARE LOOKING AT ABOUT $125 TO $150.00 WITH BATTERY BLADES AND CARB REBUILD, AND I WOULD ALMOST SAY IT WILL NEED BEARINGS IN THE DECK, BUT IF THAT IS ALL I WOULD SAY AROUND $250 I GAVE $125 FOR THIS 712H AND 48 IN DECK RUNNINGBUT I NEED TO PUT BEARINGS IN THE DECK, THEY ARE NOISY.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
ACmowerguy
Orange Level Joined: 20 Apr 2010 Location: Winfield, MO Points: 1199 |
Make sure it has the Series II engine. The Series I Kohler KT twins had lubrication problems. If it has a rear lift kit that is worth some $$$. Does it have hydro-lift or manual? If the blower is an easy fits thats another $100-$250 of value. In tip-top shape a 917 with blower and 48" deck could bring close to $700-$1000. An average good runner w/deck is probably $400-$700 depending on the location and timing. |
Ted in NE-OH
Orange Level Joined: 12 Nov 2009 Location: Austinburg OH Points: 1703 |
"carburetor rebuild" could be masking bad engine problems. Maybe carb is ok and it is really an engine problem.
ac fleet
Orange Level Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2225 |
My 917 dont idle correctly,---(has an 18 hp in it--the guy tossed in the old 17hp, so I still have the little engine)---he thought it was carb problem,--I think its more governor related myself!---will find out this spring when I can get out there to work on things! thanks; ac fleet
Post Reply | |
