8010 lights |
Post Reply |
185turbo
Bronze Level Joined: 15 Aug 2018 Location: Kansas Points: 92 |
Posted: 08 Jan 2021 at 1:11pm |
8010 is having trouble with the lights. I put all 8 lights on new.
1. When the switch is turned to hazards the hazards come on and flash but when you turn the turn signals on the side that is supposed to flash goes out and the other stays solid . 2. When the switch is turned to the road lights NO lights come on and the hazards will work like above. 3. When the switch is turned to flood lights all the lights come on My question is why the road lights position will not turn on any lights and why when the flashers are on the the turn signal will not work right? Thanks |
185 turbocharged w/ 500 loader , WD
orangereborn
Orange Level Joined: 12 Sep 2009 Location: NW WI Points: 1403 |
were your road lites HI/Lo and you replace them with the single filament??
185turbo
No i replaced them with single filament lights.
KJCHRIS
Orange Level Joined: 21 Dec 2015 Location: WC Iowa Points: 823 |
Did lights work correctly before you replaced them?
185turbo
Yes just put new ones on
Ron(AB)
Orange Level Joined: 27 Dec 2009 Location: Alberta Points: 943 |
There is an updated flasher switch for the 8000 series.
Have you installed it yet? That will make your flashers work. Re: the driving lights, you need dual beam lights for them to work in both positions. |
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
185turbo
Ok i will get the new flasher switch thanks
Post Reply | |
