8010 joystick |
Post Reply |
185turbo
Bronze Level Joined: 15 Aug 2018 Location: Kansas Points: 92 |
Posted: 07 Oct 2019 at 7:15am |
Got a 8010 powershift with a westendorf loader. The loader is controlled with the remotes now but want to put a joystick on it to run loader. Does anyone know where to get a complete kit or how to piece one together ? Would need valve , joystick, cables and adapters to plumb into hyd system. Is it a pfc or closed center hyd system?
Thanks |
185 turbocharged w/ 500 loader , WD
Joe(TX)
Orange Level Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
It is a closed center load sensing system. It would require a closed center load sense valve tee'd into the system. The load sense port is required to actuate the pump high pressure.
Surplus Center has a valve. It's not cheap, $570. The joystick controller and cables adds about $300. A selector valve for the remotes would be cheaper.
acnh210
Bronze Level Joined: 24 Nov 2010 Location: Rochester In Points: 136 |
I have one in an 8050. I bought it through westendorf (work for a dealer) it does not include hoses and was $2600 several years ago. A lot of work to install but worth it once it's in.
Terra Tiger, WD, 7040ps, 8050 with westendorf loader, 8050ps fwa.
185turbo
I looked on surplus center and i cant seem to find a ccls joystick valve on there.. do you happen to know the part number of it?
acnh210
I beleive I still have the owner's manual. Just not sure where. I'll do some digging.
Joe(TX)
The closed center load sense valve and joystick controller are listed separately. Do a search for "load sense" and "joystick". The valve is a Prince 20 series The cables and connections are also separate. The controller is 9-6704-J |
185turbo
Thanks for the help i found the valve joystick and cables. I will just have to figure out how to plumb into the supply return n load sense now
toolcat
Bronze Level Joined: 24 May 2015 Location: Council Bluffs Points: 16 |
so why couldn't you just get a joy stick controller and proper length cables and use the existing factory valves unless you are trying to add more outlets to the system.
185turbo
Only have 2 remotes , need 4
Joe(TX)
The pressure line is the one with the hose going from the pump to the remote/lift valve. You can tee in there. A 3/4 JIC swivel run tee will make it easier.
The sense line is the 1/4 tube running from the pump to the valve. A JIC swivel run tee here. Easier to install at the valve end. The return is a tube from the valve to the reservoir. I think it is 1 in.
JCFarms
Orange Level Joined: 03 Mar 2013 Location: Louisiana Points: 230 |
Joe(TX)
That's the valve. I would get the one with the float position, especially for a loader.
Michael V (NM)
Orange Level Access Joined: 12 Sep 2009 Location: NM Points: 2335 |
I would like to get one of these,,will the joy stick and cables mount to that 9-20-2-LS? I have joystick and cables,,, when I got the 8010 with a westendorf loader, it had this on it, but the wrong valve, so,,, I took it off and just run loader to the rear remotes...I found out its not good to "deadhead" the load sense pump with a closed center valve,, but it may been a open center...I'm not sure,but it's non been there for a long time....
185turbo
Any ideas on teeing into the return side of the system? The pressure and load sense are easy since they are hoses but not sure how to tie into the return since it’s a steel tube? Is there another place I could return the oil?
Orange Level Access Joined: 12 Sep 2009 Points: 19571 |
I've never done this, but have always felt you could remove the endplate on the hydraulic valve stack, drill and tap a hole that lined up with the return passage. Could also remove the cover plate under the PTO gears and drill/tap a hole in there as well, although it would need to be kept up tight to avoid hitting a rock rolling by.
MACK
Could return back to one of the sight bulb holes. MACK
185turbo
Ok . I’d rather not drill and tap if possible but will if I have to. there is a line on the front side of the right hand filter that goes forward possibly to oil cooler?
Would it be ok to plumb in the rear there? The return tube from the remotes comes in on the rear side of the right hand filter.. |
185turbo
I meant to say would it be ok to plumb in the return there, on the front side of the right hand filter
185turbo
Are the sight glasses pipe thread ? 1/2? Thanks
Not pipe thread. O-ring threads.
Joe(TX)
The line going forward is the pump suction. The one on the top is the return from the valves.
185turbo
Cant seem to find the correct oring thread for the sight glass. 1/2 nipple will screw right in though , any ideas thanks
bigal121892
Orange Level Joined: 05 Jan 2010 Location: Nebraska Points: 743 |
1/2" fitting was all we ever used.
Post Reply | |
