7040 fuel question |
Post Reply |
INAllis
Bronze Level Joined: 14 Feb 2024 Location: Indiana Points: 18 |
Posted: 22 Apr 2024 at 2:34pm |
Recently started my 7040 to move it, fired right up and ran peefecr per usual. After several minutes idling it just died instantly. Fuel Guage read about 1/4 and I am 99% it had fuel but I put about 25 gallon s or so in it but filters etc were empty while trying to bleed system realized I was not getting fuel to the filter. Disconnected the hose from auxiliary tank to filter and nothing when held above the frame rail but runs full stream when held lower. Is this line pressurized from the fuel itself or ???. I have blown air back through the hose into the tank and nothing changes I am stumped. TIA
Orange Level Access Joined: 12 Sep 2009 Points: 20169 |
The early 7040's drew fuel up thru a small plastic standpipe to the top of the LEFT tank and then it was plastic line to the fuel filter. Every one I was ever around got changed over to the updated lower hose draw which solved a lot of issues like that.
INAllis
Yes mine has a rubber hose from auxiliary tank up to the filter housing, I can get a full flow of fuel if I disconnect that hose and hold it level or lower than the outlet of the tank, anything above that.and nothing so absolutely no fuel is getting to the filter or any point beyond that. Am I missing something?? An in tank pump or ??
Lynn Marshall
Orange Level Access Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2256 |
Your hand primer pump isn't working correctly. It should pull fuel from the tank, to the injection pump, and keep it there, regardless of the amount in the tank. The plunger seal may be bad or a check valve could be stuck.
Edited by Lynn Marshall - 22 Apr 2024 at 9:36pm |
VirginiaWilson
Bronze Level Joined: 25 Apr 2024 Location: US Points: 1 |
All good now? I also would like to help you by sharing the https://casinosanalyzer.com/online-casinos/germany-deu website with you. If you love to play online casino games but can't find those sites where you can play online real money games then you can visit the given link where you will find those sites in which you can play online casino games. I am also using that website link to find online real money gaming sites and they never disappoint me.
Edited by VirginiaWilson - 01 May 2024 at 7:33am |
INAllis
No progress as of yet, I have ordered a new hand primer and will be trying that as soon as it arrives
Post Reply | |
