7020 tac playing tricks |
Post Reply |
youngorange2000
Silver Level Joined: 27 Mar 2019 Location: eastcentral MN Points: 308 |
Posted: 25 Apr 2023 at 7:32pm |
The tach on my 7020 started a new trick this year. I will start the tractor and the tac will work for about 5 minutes then nothing. It's done this three times this year. Last year about every other time I used the tractor I would start the tractor the tac wouldn't work for the first few minutes then it was like a light switch and it would work and stay working. Is there a pickup sensor somewhere that's finally given out? Thanks
MACK
First thing, tighten fan belt. If alt. pulley is Shiney in the bottom, replace pulley and belts. MACK
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77944 |
Luke, the tach gets its signal from an output on the alternator...
Joe(OH)
Orange Level Joined: 11 Sep 2009 Location: Montezuma, Ohio Points: 965 |
I had something similar years ago on a 7000 and a 7020. Wasn't long after playing that trick that it needed a new alternator.
Life is simpler when you plow around the stump.
youngorange2000
Belts are tight doesn't change it all wire connections are tight on the altinator
Jack(Ky)
Orange Level Joined: 12 Sep 2009 Location: Ky Points: 1151 |
My 7020 did that and it was the alternator going bad.
'59 D14 '68 170 Diesel '81 7020 40 All Crop
Post Reply | |
