7020 pto problem |
Post Reply |
youngorange2000
Silver Level Joined: 27 Mar 2019 Location: eastcentral MN Points: 308 |
Posted: 12 May 2022 at 5:18pm |
I am in the process of replacing the seals on my 7020 pto. I drained the fluid removed the safety wire and pin loosened the big nut and went to pull the 1000 rpm shaft out and got it about 4 inches out and is now stuck and won't go in or out. There's a bearing on the inside of the shaft that's stuck up against the big nut. I have tried working the shaft in all directions and tried gently prying inbetween the bearing and big nut and it will not budge. I'm stumped
Orange Level Access Joined: 12 Sep 2009 Points: 19573 |
You need a BIG slide hammer attached to the outside end of the 1000 RPM shaft and slide hammer that bearing off.
youngorange2000
I got the PTO seals done. I ended up using 3 7 inch 7/16 bolts going through the 1000 spline shaft and the PTO itself as a slide hammer. The stuck bearing came out with half a dozen light taps of the makeshift slide hammer. Thanks for the help
Lynn Marshall
Orange Level Access Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2154 |
That's the way I've always done it.
shameless dude
Orange Level Joined: 10 Apr 2017 Location: east NE Points: 13611 |
yep...me too, mine needs it again
Post Reply | |
