616-620-720 Mower deck shells |
Post Reply |
Tracy Martin TN
Orange Level Access Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10567 |
Posted: 18 Mar 2015 at 12:46pm |
There is a gazillion hours to reproducing the deck shells and seems there is no end. Getting close to completing them though.This has been a challenge to keep them as original as possible. I tink I will have 3 to sell if anyone is interested in them. Tracy
Pat SW Ohio
Silver Level Joined: 30 Dec 2009 Location: Wilmington, OH Points: 74 |
I'm interested...what kinda money you talking about? Thanks, Pat
Tracy Martin TN
Pat, probably around the $1500 mark.They will be very professional.They are thicker than originals on the deck itself. The brackets will be same thickness as originals. It is basically just the deck, no height control on rear. I will post pics when I get them done. Thanks for the interest. Tracy
Dgrader
Orange Level Joined: 17 Jan 2015 Location: Newton,IL Points: 1037 |
I'd say it would be a challenge to build those decks. Rather time consuming to I would guess.
Ya cain't fix stupid.
Tracy Martin TN
BrianC
Orange Level Joined: 16 Jun 2011 Location: New York Points: 1613 |
Thanks(1)
Just the deck shell and anything welded to it? So for someone with
a worn through, rusted, bent and re-welded mower, they would swap the existing parts over to your new shell. That seems like a logical approach. As for the price, nobody wants to part with hard earned money, but for a low rate special custom reproduction I think that is fair, in my opinion. My deck is in good shape however. |
Tracy Martin TN
Edited by Tracy Martin TN - 20 Mar 2015 at 4:13pm |
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11568 |
Thanks(1)
Tracy,
I've seen your work brother. You're spot on when it comes to your repro's man! They're probably "tits".... LOL! Steve@B&B |
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8156 |
Hi Tracy. What do you use for the rod for the rollers. Thanks
Tracy Martin TN
Mike I use 5/8 dia. shafting(CRS). HTH Tracy
coggonobrien
Orange Level Access Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1806 |
what gauge did you go for the new shells?
Tracy Martin TN
Mikez
Ok thanks
coggonobrien
We're the originals 10 gauge?
Mikez
What do ou do with the slides 2172567, there no longer available. My uncle is going to make me some on his lath
Tracy Martin TN
Mike, I don't have my manual here at home. What part are you referring to?Tracy
Mikez
Oh yup it's the 3/4x3/4" square piece that is on a shouldered bolt, goes in the slide for the roller height adjustment
Tracy Martin TN
They would be easy to make. The less lost motion in the roller assembly, the better off you will be. I made all new brackets that hold the axle and bolt to rear deck brackets. Mine were worn bad. HTH Tracy
Mikez
Yea they do look easy enough to make. Was just curious how others were fixing it up.thanks
Post Reply | |
