616/620/720 mower deck roller dissassembly |
Post Reply |
coggonobrien
Orange Level Access Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1807 |
Posted: 12 Apr 2015 at 7:51pm |
just wondering how you remove by sets of rollers.
Thanks! David |
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7207 |
Referring to the picture below, remove each shoulder bolt that is above the roller assembly. Also remove the bolt directly above. The shaft is welded to the upright on the right side, so you start pulling on that upright to get everything apart. If you are rebuilding, I'd recommend welding on a new shaft as the original is probably well worn.
Did mine a few years ago. Had my fab shop make up new uprights as well since mine were worn too. |
Tracy Martin TN
Orange Level Access Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10570 |
I made those over also. Mine were worn too. I made new deck adjusting Tee handles also. Take out all the lost motion as much possible.Tracy
coggonobrien
cool thanks, how about the small roller inside the shell?
ACJohn
Silver Level Joined: 12 Sep 2009 Location: Horseheads, NY Points: 147 |
IIRC, you have to unbolt the brackets for the roller behind the center blade.
Post Reply | |
