410 Shuttle |
Post Reply |
A-Cvtx
Silver Level Joined: 09 Jan 2015 Location: NC Points: 71 |
Posted: 21 Jun 2015 at 8:03pm |
Yesterday while pushing some dirt and gravel, my 410 shuttle would stop moving when it got a load on the blade. Not a large load, what I would call a fair load. Any suggestions as to adjustments? What to start? What to check? Thanks!!
Insanity is relative. All of my relatives are crazy!
Gary
Orange Level Access Joined: 13 Sep 2009 Location: Peterborough,On Points: 5173 |
Isn't a 'Shuttle' belt drive with a geared transmission? So a stop in motion would mean a belt is slipping ? Or do you mean 'Hydrostatic' drive ? Gary |
A-Cvtx
That's the belt drive. Its 4 speed with F/R shuttle. I didn't have the usual symptoms. Smell of hot belts or squealing. Probably just need to check my tension. Huh?
farmtoybuilder
Orange Level Joined: 11 Sep 2009 Location: Dresden,Ohio Points: 1449 |
Belt tension and belts could be wore out! We have put heavier spring on for heavy loads as pulling. If it slips in first it needs some work.
DaveBsACs
Bronze Level Joined: 21 Jun 2015 Location: Iowa Points: 15 |
Sure sounds like belt slipping, I have found a new set of belts will cure that, just be aware that they can be grabby untill they have some wear on them. |
A-Cvtx
I checked the belts. They look ok, just a little loose. Gonna replace spring with a heavier spring, as per farmtoybuilder, and go from there.
Post Reply | |
