220 Engine |
Page <12 |
Author | |||
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21721 |
re: replace or regrind option couple of points to consider 1) cost to regrind your crankshaft ? 2) cost to buy another carankshaft ? include shipping ! and bearing set !! 3) you'll need a bearing set or at least 1 pair. 4) you KNOW your crank is good,well no hidden defects...everything fits.. If done proper a replaced bearing set will outlive me. Jay |
Sponsored Links | |||
A-C_220 ![]() Bronze Level ![]() ![]() Joined: 05 Jan 2019 Location: Canada Points: 91 |
Will a crank out of a 7040 work in my older engine with no modifications? Or would I be better off rebuilding the 7040 engine and bolt it in.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 19716 |
7040 crank will go right in with no issues.
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 11441 |
Kind of funny.....but....why?
Would a D21 block work with the crank driven oil pump off the 220? and is there any other problems with putting the 220 parts on the D21 block.
Block would need to have two mounting holes drilled/tapped I think.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8075 |
Didn't they jet the mains on higher hp 7000's before the rifle drilled rods system came out? Might want some piston cooling if pushing 200hp. My 220 got jet tubes from a Binder block installed at O/H.
Early design piston cooling has a small hole drilled in the upper main brg saddle. Could be done on an older D21/210/220 block if desired but needs crankshaft driven oil pump to have enough oil GPM's.
Edited by DrAllis - 07 May 2019 at 6:04am |
Mine does and I had to crank the regulator to get oil pressure back up LOL
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29781 |
Wink I am a Russian Bot |
Few things here: First off, hello pot, I'm kettle! ![]() 2nd, I was not the first or only one to say something similar. And most importantly, thanks for calling me out nearly 4 MONTHS later!!! ![]() ![]() ![]() ![]() As for the "joke", do either of us know it's a joke? Seems more snark than joke to me, but I could be wrong. Always a pleasure Lonn
![]() Edited by Tbone95 - 08 May 2019 at 8:04am |
steve fischer ![]() Orange Level ![]() Joined: 11 Jul 2011 Location: sleepy eye mn Points: 933 |
have rebuilt engines and parts if you want to rebuild yours thanks Steve 507-766-0551
Page <12 |
