201 engine assembly |
Post Reply | Page <1234> |
Ted J
Orange Level Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18704 |
Nice job so far Marv!! Good documentation and the pics are great! Not out of focus or anything. GREAT job!
I've got a good idea how you're going to get it out of the basement....... I did it with a piano once.... |
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77733 |
you mentioned a rolling resistance of 250 inch pounds with the pistons and bearings installed.... I have measured 20- 25 ft pounds in the past, which is similar... I agree.
allischalmerguy
Orange Level Joined: 11 Sep 2009 Location: Deep River, IA Points: 2864 |
Marv,
I am enjoying your photo documentary. It is very interesting to me. I did not grow up with a Dad who could do this, or near a shop that did it. I find it very fascinating and way above my head. I wish I could of learned this skill. Thanks for sharing. Mike |
littlemarv
Orange Level Joined: 10 Jun 2013 Location: Wisconsin Points: 1826 |
O.K., got the head back. I thought everything looked pretty good, but they really went through it. All new guides, 4 new seats, added valve stem seals, pressure tested, resurfaced, cleaned, and new frost plugs.
I also dropped off the manifold as well. I really only wanted it baked and blasted to get all the crud out of the intake side, but they gave it the once over as well. They machined the carb gasket surface, the manifold surface, and took the cover off and pulled the studs and machined that surface too. I have heard stories of the manifold being machined too much and then the carb hits the block? Also heard of machining it at an angle to prevent that? At any rate, we will see how that turns out- I am not putting on the manifold yet, I plan on taking the engine outside and priming every nook and cranny before bolting the manifold and the mag on. Does anyone make a gasket for the manifold cover, otherwise I can make one... So, gave the headgasket a snort of copper coat, and laid it down. The gasket was stamped "UP", but that had XXXXXX printed over it, and "THIS SIDE UP" was printed on the opposite side. I had a 50/50 chance, so I put the printed side up. They also reground the radius on all the rocker arms. Those were very worn. Good as new! Got the rockers put back together. Torqued the head to 70 foot pounds, installed the water manifold, push rods, and rocker shaft assembly. Torqued the rockers to 25 foot pounds, and set the valves to 0.014" cold. I figure that should be close enough until I can run it to check it hot, and retorque the head while I'm in there. Trued up the oil filter base, because that had been way overtightened, like pretty much every other one. Installed the dipstick bushing, oil pressure regulator, pushrod cover, filter base, and oil lines. Edited by littlemarv - 02 Sep 2017 at 9:05pm |
The mechanic always wins.
B91131, WC23065, WD89101, CA29479, B1, Early B10, HB212, 416H |
Allis dave
Orange Level Joined: 10 May 2012 Location: Northern IN Points: 2849 |
Making great progress again. Looks like you had a good Easter weekend. It's good to see everything coming together nicely.
allischalmerguy
Great work very educational. Thank you for sharing and the photos!
Phil48ACWC
Silver Level Joined: 17 Jan 2013 Location: Vermont Points: 278 |
Check video below. This is the proper way to safety wire. You don't need the expensive spinner pliers.
https://www.youtube.com/watch?v=XktwpWPFvHs |
BenGiBoy
Orange Level Joined: 11 Nov 2015 Location: Ashville, NY Points: 696 |
'39 Model B
Tractors are cheaper than girls, remember that! |
Sugarmaker
Orange Level Joined: 12 Jul 2013 Location: Albion PA Points: 8167 |
Marv,
Just awesome documentation on a WC engine build. Maybe even I could do one someday too. Thanks for taking the time to do this. Glad to see the kids helping too. Regards, Chris |
LeonR2013
Orange Level Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
I'm a clean freak also. But I don't have leaks so there is benefit. Have you ever seen a set of bearings that were installed in a dirty engine? NOT good. That's why I like to spin the pump if possible. It can wash some of the dirt out left in inadvertenly. Good job. Leon R Cmo
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7981 |
littlemarv,I'm not certain here,but I believe it has been said not to use seals on valves on these engines because the guides will wear quickly.Need to check with MACK or Drallis or any other know quanity....
Edited by SteveM C/IL - 03 Apr 2016 at 8:43pm |
structures
Silver Level Joined: 28 Feb 2011 Location: Beggs, OK Points: 331 |
Great build. Great detail and pics! On the head gasket for my 160cu in D15II the gasket was almost reversible. There was a hole at the back of the block but also the water path holes were progressively larger from back to front. It appears your gasket might be similar.
Robert
1964 D15 Series II |
littlemarv
Installed an oil filter (made sure it is the stuffed kind, not pleated paper) and built a custom lifting bracket. Also installed a 1 ton chain hoist in the ceiling of the basement.
Borrowed the preluber from work. You put oil in the tank, pressurize it with compressed air, hook it into the oil galley, and fill the oil system to eliminate dry startups. Plumbed in where the oil pump delivery line from the oil pump goes. Took awhile to fill the system, but eventually I had oil coming out all the mains, the rods, and all the rockers. Its neat how oil runs down the rockers to lubricate the push rod sockets and valve stems. Not sure if the preluber is higher pressure and lower flow versus the oil pump, but the relief valve opened right away, so I plugged the ports with my fingers, and then the gauge would register. We'll see how it acts when I fire it up......someday. Edited by littlemarv - 02 Sep 2017 at 9:10pm |
TomMN
Orange Level Joined: 13 Sep 2009 Location: Elbow Lake, MN Points: 858 |
Very nice. I have only seen the oil flowing up top with the engine running and the cover off. Fun to see it in a steady state as the oil flows through where the designers intended.
littlemarv
Flipped the engine over.
I thought the safety wire videos were really neat, so I redid those. Installed the oil pump. Yes, that is Don's oil pan video in the background. Put the pan on, torqued the bolts to 18 foot pounds. Flipped it back up, put the valve cover on just snug, and installed these stands I welded up out of some scrap iron I had laying around. So there it is. I think I will put the water pump on, then up the stairs she goes, out to the garage for a coat of primer. Thanks for looking! Edited by littlemarv - 02 Sep 2017 at 9:18pm |
Don(MO)
Orange Level Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
She is looking good, I'm happy to see you rewired the main cap bolts. I have built lots of engine stands so the engine can ship and you have a nice set built. Now it's time to move her out of the house and please post some shots of it going up the steps and out the door. lol
BenGiBoy
Definitely some pictures of 'the trip out'!
'39 Model B
BenGiBoy
Lookin' real good, by the way. It is fun to watch your progress!!
'39 Model B
IBWD MIke
Orange Level Joined: 08 Apr 2012 Location: Newton Ia. Points: 3445 |
When I rebuilt the engine for my 45 I had to use a WD block. Learning how to safety wire was one of the more interesting parts of the job.
littlemarv
When I got the manifold back, they had taken the cover off and cleaned it out. I never thought to look closely, I just thought "Huh, looks like I need to get some exhaust gasket paper and make one for this, so the intake and exhaust gases don't mix."
So, I picked up a sheet of exhaust gasket paper. Boy is that some crap to work with. It has metal in it so custom trimming is pretty tough. At any rate, now that I look at it, that upper chamber does nothing. I thought that was the intake side of the manifold, but it is more or less a sealed chamber. Nothing goes in and out of it as far as I can tell. Whats it even for? Does that have something to do with the "G" or "K" covers you can get? Anyways, made a gasket and installed the cover with some new brass nuts. Masked off the carb surface, out to the paint booth tomorrow, for some extra high temp primer and paint. I don't know how hot the old manifold will get, but I figure the stuff rated for 3000 degrees ought to cover it. (Yeah right) Edited by littlemarv - 02 Sep 2017 at 9:27pm |
SteveM C/IL
Yes it does.the K cover is made so the exhaust heats the intake pipe which doesn't work so good for gasoline.
BenGiBoy
K stands for Kerosene probably.
'39 Model B
cdweirrick
Bronze Level Joined: 19 Apr 2016 Location: Mercer Co, OH Points: 41 |
I have loved reading this thread. As someone who is new to all of this and looking forward to learning, it has been full of valuable information. I cant wait to see the finished product!
Grandpa's 1950 WD
1950 G |
littlemarv
Time to get the motor outside. I had to take the valve cover back off, because now that I put the pan and stands on, its too tall. Put a piece of pipe up in the floor joists to hang my hoist from. Big brother stopped by, and we lifted the engine and ever so gently slid it off the bench. Set the two wheeled cart under it and lowered it down.
Ratchet strapped it to the cart, and up the stairs we went. He was pulling, and I would lift up each step, and it really went pretty good. Didn't have a photographer when we really needed it, and our hands were definitely full! But here it is rolling out the kitchen door... So there, a successful trip out. Needs to go out to the paint booth for a coat of primer. Then the chassis needs to come into the garage and we can set her home. Edited by littlemarv - 02 Sep 2017 at 9:28pm |
B26240
Orange Level Joined: 21 Nov 2009 Location: mn Points: 3860 |
Less dramatic than I thought the trip up the stairs would be, all I can say is you and your brother must be some "heavy duty guys". My fear would be getting it up to stair number four and running out of gas. Mark
KenBWisc
Orange Level Joined: 15 Sep 2009 Location: Fall Creek, WI Points: 1164 |
I don't understand why the pics of your rolling chassis don't appear here as they did in an E-mail notification I received. But,,, in relation to steering wheel slop; find the bearing adjusting bolt under the pedestal and between the two front wheels. Tighten this a bit at a time while checking for reduced slop. It may take care of it for you.
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
CAL(KS)
Orange Level Joined: 18 Sep 2009 Location: Chapman, KS Points: 3734 |
Doing a great job documenting this project. Curious why you opted to stay with the old style water outlet instead of the later with thermostat for automatic temp control.
littlemarv
I went with the no thermostat one for a couple reasons. First off, I have three thermostat housings, three of which became perforated when I tried to clean them up. Second, I'm not sure how many combinations of water manifold-head thickness-radiator necks there are. But I think this is original? Not sure, we will see once I get the motor in and radiator set down. I may have to change something.
Sugarmaker
Very nice documentation on your engine build! Thanks for posting the details.
Regards, Chris |
LeonR2013
Something I do is that on any exhaust and the four on that plate, I use stainless nuts and lock washers. They don't rust in place as bad, which can give you headache. Leon R Cmo
