190XT series 3 vs 7000 maroon belly hydraulic pump |
Post Reply |
youngorange2000
Silver Level Joined: 27 Mar 2019 Location: eastcentral MN Points: 308 |
Posted: 15 Jan 2023 at 2:39pm |
Does anyone have any info on the specs and differences between the two. Thanks
Orange Level Access Joined: 12 Sep 2009 Points: 19573 |
A very late model 190XT dual-pump had gears that were .700" wide and delivered 4.25 GPM to the steering via the priority valve spool. The early 200's were the same. Later 200's and maroon 7000's had .900" wide gears and depending on which tractor delivered 6 GPM (200) or 8 GPM (7000) to the priority circuit. The priority valve spool was set-up to deliver the different GPM's because of hydraulic circuit needs for each specific model. What are you trying to do ??
youngorange2000
My late series 3 pump had a bad main drive shaft and I got a a used maroon pump for next to nothing I want to use instead they look very similar with the exception of the flow devider. My question is can I run the maroon pump instead without any problems? Thanks
Thanks(1)
Your tractor was set-up for 4.25 GPM for the steering and Power Director/PTO clutch circuit. At a minimum, I'd be checking the P.D. clutch pressures to be sure they aren't too high !! especially at full throttle. It might be wise to remove any shims inside the priority spool to help cut down on that 8 GPM priority circuit flow. I've never done this, but I don't scare easily.
DCAC
Orange Level Joined: 20 Oct 2018 Location: east central SD Points: 510 |
What's the serial number of your 190?
youngorange2000
30507
youngorange2000
Would there be a problem running a higher gpm pump off of the camshaft? When the original pump went out it locked up and broke the camshaft and the tractor got the updated cam and bolt on gear from a early 7000.
tbran
Orange Level Joined: 14 Sep 2009 Location: Paris Tn Points: 3244 |
no , but as Doc stated, the concern is the PS PD flow area. We just don't want to put more in than can be bypassed w/o upping the pressure. Follow his advice and test it and see. My bet is the slight wear will drop the GPM to a point it will work and improve the hyd performance ...
youngorange2000
Does anyone know if there's different steering cylinders and orbital for the late 200-7000 maroon with the higher gpm or are they the same as a late 190xt would have?
Power steering orbitrol is 70249505 on a 190XT and a maroon 7000.
Post Reply | |
