190XT camshaft replacement |
Post Reply |
youngorange2000
Silver Level Joined: 27 Mar 2019 Location: eastcentral MN Points: 308 |
Posted: 28 May 2022 at 10:59am |
Last fall i had the hydraulic pump on my series 3 suck up a part of a power director disc and lock up. This tractor had the sump screen removed at some time and i will be replacing that screen. My question is can i remove the front axle assembly and front cover plate and replace the cam that way somehow holding the lifters from above? Thanks
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7946 |
This seem crazy but it works- go to Dollar General and get clothes pins and dowel rods from a hardware store - AC even has this in the fix it manual, tap the dowel rods in the lifter, snap it with a clothes pin - holds it up and works
youngorange2000
Does anyone know what size dowels? Thanks
Lynn Marshall
Orange Level Access Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2154 |
The pan will have to come down to remove the engine oil pump too.
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8030 |
did the series 3 use the cam drive pump?
youngorange2000
Yes cam driven oil pump and cam driven hydraulic pump
Post Reply | |
