180 power director issues
baverwolf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Topic: 180 power director issues
    Posted: 22 Apr 2017 at 10:10am
Hi, my uncle has a 180 Allis and he is having some problems with the power director. He says that sometimes it won't engage when going from neutral to high or low and also sometimes won't disengage. He says once it engages it doesn't slip. He's thinking something is maybe hanging up or a hydraulic port or orfice is partially plugged. He also said that at lower rpms there is a hydraulic chatter or vibration. So, could the hydraulic pump possibly be bad or not developing the needed pressure to shift the power director?? I haven't been around the 100 series much so I don't totally understand how the power director works but I do understand that the power director is hydraulic if I'm not mistaken. Any ideas on where to start diagnosing??
Thanks!
Ben
Edited by baverwolf - 22 Apr 2017 at 10:11am
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2017 at 10:41am
90% chance it is mechanical - broke clutch plates in the pd clutch unit.
the unit not disengaging is the culprit to diagnostics.
 You can pull the kick panel and check the hyd pressures easily.
IF the pressures are close to correct - you have a mechanical portion of the pd  system that had failed.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2017 at 11:54am
The first think to check would be the linkage to the valve. Make sure it is fully shifting the valve.
Next I would be checking the pressures. You may not be getting enough flow at low rpm to maintain pressure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2017 at 12:37pm
Power Director linkage is pretty much trouble free. Start with two 500 psi gauges connected at the manifold below the platform where the brake latch pawl pivots on. One allen head plug is for Low and the other for High. Your Uncle needs to pay attention when the tractor doesn't move if the POWER STEERING is working or not, as the same pump is for both functions. I assume he's checked the hydraulic oil level ?? which is to the LEFT of the gearshift--a threaded-in dipstick. I'm thinking broken discs inside, but time and testing will tell. Removal of the side cover and a visual inspection of the clutch will reveal broken plates pretty easily.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2017 at 10:17pm
Pressure regulator sticking at idle is common on the 180. Nut on bottom of valve. Remove valve and polish it up.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2017 at 10:28pm
Thank you guys for all the good advice and tips. Ill pass on the info to my uncle and hopefully he can get something figured out. In the meantime, keep the good advice coming!
Thanks!
Ben
