170 175 tach |
Post Reply |
rick ky
Bronze Level Joined: 02 Oct 2009 Location: georgetown ky Points: 91 |
Posted: 04 Apr 2024 at 5:36pm |
put together allis motor 226 with alternator from 236 diesel, everything is coming together fine. red light works when key is turned on, goes out when oil pressure is increasing. alternator is putting out 14 volts. fuel gauge is working properly. temperature gauge working, increasing when motor is warming up. tach is running around 1,000 on low idle, but it buries the needle at half throttle. parts book shows 2 different tachs, 1 for gas and 1 for diesel. we know the tach is original for the dash, it is a gasoline engine tach. what thoughts are out there on how possibly to fix the problem? we want the tractor to operate as close to new as my nephew will have his wife driving the square baler while he is loading the wagon.
JC-WI
Orange Level Access Joined: 11 Sep 2009 Location: wisconsin Points: 33660 |
Got the wrong size pulley on alternator?
rick ky
what size is a suggested diameter choice. thanks for input
captaindana
Orange Level Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2374 |
If the rear of the alternator drives the tachometer, I thought there was different size gears in there for different applications
Blue Skies and Tail Winds
Dana |
rick ky
just fishing to see if anyone has come up with any ideas on changing gear in alternator or what size pulley should be on alternator
rick ky
okay boys and girls we have put the largest pulley on alternator. what suggestions do you mechanics have now. is it in the tach drive on back of alternator. thanks to anyone able to shed any info on this problem. thanks again
Oldoug
Orange Level Access Joined: 12 Sep 2009 Points: 1105 |
Check the drive gears on the alternator and count the teeth for starters...big gear should be 46 if I remember correctly...some people have accidentally put 43 tooth gears in them and the tach reads faster.
Matt Folkers
FOLKERS RESTORATION Restoring vintage things to last so the future can enjoy our past. |
rick ky
thanks doug
Post Reply | |
