149 in CA probs
1955allisca View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955allisca Quote  Post ReplyReply Direct Link To This Post Topic: 149 in CA probs
    Posted: 05 Jan 2015 at 9:26am
I am in the process of putting a G149 in my CA what do i do about making the oil fill pipe go straight up?
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2015 at 10:51am
On Little Pink Tractor, I unscrew the oil filter and put oil in that way. It has a 160 engine.
Edited by Burgie - 05 Jan 2015 at 10:53am
"Burgie"
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2015 at 12:02pm
I think he means the cap is in the way of the hood. I think you would plug it so that is can still breathe and then add oil as Burgie said.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2015 at 5:58pm
I would think that you'd have to rework the valvecover to get the oil fill/breather up through the hood. There is no valvecover that I know if for the 138/149/160 engines that would have that configuration. That's something I never bothered with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955allisca Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2015 at 10:30pm
Okay thanks i was just wonderin if there were any quick easy fixes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2015 at 10:03am
After thinking a bit, you could use a D10/12 valve cover and move the oil fill/breather hole in the hood forward to match up. Not ideal but workable.
