#1 or 4?
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Topic: #1 or 4?
    Posted: 08 Apr 2013 at 7:53am
Is this a #1 or #4 plow? I'm guessing a #4 as I'm thinking the rear wheel is too large of a #1??
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2013 at 12:43pm
No one knows? Must be a rare one!!
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2013 at 7:07pm
it is a #2 i have 3 of them
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2013 at 7:28pm
have one like that on rubber an steel behind for yard display
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2013 at 8:18am
Sure seems lighter duty than my #2 including smaller clutch although the tail wheel is the same.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2013 at 8:37am
I still vote that it is a #2 plow, but I know what you mean Ken, I have a #2 plow that is very heavy duty built and also have other #2 plows that are a lot lighter built.
because of the axle cap that sticks out from the wheel that proves that is not a #4 plow, they were different.
It could "possibly" be a #1 plow. Can you find any casting numbers on it anywhere?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2013 at 9:13am
Huh! A feller learns something everyday!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2013 at 10:05am
What is the hub cap casting number? This is the easiest way to see if it's a #1 or #2 plow   Matt
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2015 at 5:41pm
My vote is #1, axles too small for a #2, and hubs and no slotted straps rule out a #4.
